need an alighnment?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
need an alighnment?
iv just recently replaced my inner and outter tierod ends, front and rear swaybar end links, rear shocks, in the spring i will be doing front struts and strut mounts and i also added a wonderbar. do i need to get an alighnment done after replacing all of these even if i do my best to get these just like the should be?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: need an alighnment?
You should, but if the car still drives straigtht your ok. However if it is off you can wear out the tires prematurely.
Stell1579
Nov 12, 2001 07:24 PM
