Sub frame replacement
Old Jan 25, 2012 | 09:58 PM
nemisis02's Avatar
Car: 1986 Trans Am and 1995 Sierra 1500
Engine: 350 small block in both vehicles
I am trying to find replacement sub frame components for my car. Restoring it and really need new sub frames or ones that are in good shape from a salvaged vehicle. As of now have had no luck in finding anything. Have contacted Hawkthirdgen and they said to use BMR boxed sub frames but have not been able to locate anything but boxed sub frame connecters not the actual sub frames. Need help with out the sub frame replacement the project is a lost cause, may be a lost cause regardless but would rather try and not succeed then not try at all.
Old Jan 26, 2012 | 02:43 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Sub frame replacement
Is this the piece you are loking at replacing??
Old Jan 26, 2012 | 07:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Do you mean a subframe or a front k-member?
The subframes in a third gen are not easily replaced. Unlike a first or second gen where they are bolted to the body, a third gen subframe is part of the body. Third gens are a unibody. If a subframe is damaged then the car was in an accident and needs to be straightened on an alignment rack. If the subframe is rotten then the body is typically scrap because the cost to repair can become much higher than what the car is worth.
If it's just the k-member then it's simply bolted to the subframe. Factory ones are not going to be found except from a junkyard but there are many aftermarket tubular replacements.
Old Jan 27, 2012 | 05:02 PM
nemisis02's Avatar
Thanks 6SIX6 that looks like a front subframe piece. My front subframes are still in good condition, what I am really needing are rear subframe pieces. I am hoping to be able to restore the car, for sentimental reasons not to increase or sell it.
Old Jan 30, 2012 | 06:55 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
here is a link to the rear frame rails, they are not cheap at $750 each
http://www.classicindustries.com/cam...=1991&p=1&sb=0
Old Feb 12, 2025 | 06:37 PM
Ironman4life's Avatar
Car: 1984 Trans-am
Attachment 376618
I am looking for these I need both right and left sides do you have or know a site I can visit to get a pair these are what the transmission cross member attach to correct
Old Feb 12, 2025 | 07:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If your car is that bad I'd find a roller chassis and go from there. These cars are hard to "get square" once rot creeps in. It's a lot of money and work for a suboptimal outcome.
Old Feb 16, 2025 | 09:33 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Buy another car if you need to be replacing subframes. Strip everything you want off the car you have now for parts and go search for a roller or a good running car. Replacing the subframe while it can be done isn't gonna be the easiest job and you probably don't want to be opening up that can of worms regardless
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
gta90
Sep 15, 2015 04:00 PM
