Cutting Moroso trick springs
Old Feb 1, 2012 | 06:47 PM
Beeman's Avatar
Anyone have any experience with cutting these springs? I just put a set in I bought that were used, should have all of the settle out of them. My car now sits about 1 1/2" higher then before the swap. How much did you cut and how much did it drop when you cut them? I really don't want this to be an over and over type job so I'd like to do it one time. I'd like to get back to where I was or an inch lower.
Old Feb 4, 2012 | 08:30 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Cutting Moroso trick springs
This is off the subject a little but did you have trouble getting the springs in there with mine it was a battle. I need to do it again because I was stupid,stupid,stupid and didn't replace the lca bushings the first time.
Old Feb 4, 2012 | 09:07 AM
Beeman's Avatar
I used a Snap-On Branic spring compressor. You definitely have to compress them down a long way but it wasn't too bad. I do have a lift so it makes it easier.
http://www.ebay.com/itm/Snap-Coil-Sp...item1c23506484
This is the coil spring comnpressor I have. You slide the fork in the lower spring coils and clamp it all down. I ued an impact gun and ran it down as tight as possible. The stud in the center was at the top of the spring. The only thing that I would do different is possibly use a short pipe nipple on the threaded part at the bottom to shorten up the threaded part. If you compress more then I did the threads hit the frame at the center of the spring cup. Either that or drill a hole in the spring cup in the frame.
Old Feb 4, 2012 | 09:16 AM
Edwardgp's Avatar
Engine: 454-350
Wow I been looking for a heavy duty spring compressor that would handle the high lift springs easier. Thanks for posting the picture, the one I was using with the impact was starting to straighten out the hooks by the time I had them compressed enough. I was getting really nervous and didn't want to use that compressor again.
Old Feb 4, 2012 | 10:34 AM
Beeman's Avatar
I've used them all and this is the strongest I've ever used. I've had this for about 30 years and it's been lent out countless #'s of times. Don't get me wrong holding a compressed spring like this as you put it in the A arm is still exciting.
Old Feb 5, 2012 | 11:59 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Not sure if this helps, but I found this thread.
In post 8. Matt has a picture of his car with trick front springs and 2 coils cut off I believe.
https://www.thirdgen.org/forums/orga...l-springs.html
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
hdis2002
Sep 8, 2015 02:52 PM
lakeffect2
Sep 7, 2015 03:52 PM
FormulasOnly
Sep 6, 2015 10:42 AM
