poly torque arm bushing question
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: poly torque arm bushing question
increase if anything since its stiffer and will transmit more noise than a soft rubber on will
Car: 83Z28 HO
Transmission: G Force 5 speed
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Probably depend a lot on what you do with the car whether you notice any difference. If you're just cruising around probably nothing but then you wouldn't need a poly bushing. If you're doing something exciting it'll transmit more vibration but you may not notice in all the excitement.
Car: 83Z28 HO
If your rubber one is shot, it may decrease vibrations. If you're upgrading just because it's the right thing to do for performance and "feel", then it may increase vibration slightly.
ramey
ramey
ambainb
Apr 25, 2016 09:21 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
