springs making noise?
Old Apr 16, 2012 | 09:46 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
iv had this noise up front front around the strut and spring area for almost 2 years now, iv recently replaced the front struts and strut mounts and the noise is still there so im thinking its my springs flexing, it only happens when i go over bumbs or hit a pothole and the front end flexs, i think maybe the front spring isolators finally wore off or broke so my springs are making the noise? its mainly my driverside but my passenger is making it aswell.
Old Apr 17, 2012 | 10:29 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Re: springs making noise?
Have you checked the rubber "spring isolators" at the top of the spring to see if they're still in place?
Old Apr 17, 2012 | 10:47 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
You never said what the noise is or sounds like.
Old Apr 17, 2012 | 02:35 PM
Engine: L31 350
I dont know what they look like to be able to look and it makes like a flexing sound, like metal flexing. It's near my foot when the driver sides makes the noise
Old Apr 17, 2012 | 08:21 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
mine does it too..
Old Apr 17, 2012 | 09:13 PM
Engine: L31 350
is it spring flex or body flex? what is it because it really bothers me and right after i got the car it didnt do it so im lost. if it is the spring insulators where can i get new ones?
Old Apr 19, 2012 | 06:07 AM
Engine: L31 350
Bump
Old Apr 19, 2012 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.spohn.net/shop/1982-1992-...Isolators.html
JamesC
Old Apr 19, 2012 | 07:26 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
When I got under mine to look for noise causing problems I found the driver side K member bolts loose. That took care of that one noise.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
