Caster question
Old May 8, 2012 | 09:44 AM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Caster question
What is the best degree of caster for handling on our cars? Im making strut mounts and i want to know if i should change the caster angle at all. Thanks
Old May 8, 2012 | 10:55 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
Re: Caster question
If your making your own mounts, I would try and copy one of the existing designs. They allow for additional caster adjustment over the stock ones. Most of the recommended alignment settings I found for street cars had caster in the 5.0 to 6.0 range.
Old May 8, 2012 | 07:08 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: Caster question
How far is that from the stock caster setting?
Old May 8, 2012 | 08:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Caster question
Not far, stock is around 4 I think.
You are aware the stock mounts have caster adjustment right?
Old May 8, 2012 | 08:51 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: Caster question
Yes mine are jus worn out and i need more stut travel because my car is lowered so im jus goin to make some. The design is pretty simple
Old May 8, 2012 | 08:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Caster question
what are you using for a bearing for the top?
Old May 10, 2012 | 09:25 AM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: Caster question
Im using a sperical bearing.
http://www.racereadyproducts.com/med...--fks-tpdf.pdf
And retainer cup
http://www.racereadyproducts.com/fk-...l-bearing-cups
Old May 11, 2012 | 12:04 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: Caster question
https://www.thirdgen.org/forums/post...2-post506.html
I used the wide body bearings for mine. Was having some feed issues with my MIG, not my greatest welds.
Sphericals aren't made for axial loading and the wide series is rated a little higher. Of course that means custom cups. I've seen a lot of camber plates use the standard sphericals so its probably not needed. Good call on the FK's, one my QA1's already has some slop in it.
Truthfully, there's no good reason to make your own. J&M has a lifetime warranty on bearings for their mounts and I've seen them on sale well below $200. I built my strut mounts just for a fabrication project, but I still need to go back and do some more fab to make the camber slots longer.
Old May 12, 2012 | 07:47 AM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: Caster question
Yea it is just kind of a fun project for the experience but if these dont hold up i guess ill buy some
Amillionoh7
May 24, 2020 08:01 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
