modify lca's to lower spring down?
Old May 20, 2012 | 06:07 PM
  #51
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: modify lca's to lower spring down?
I've never lowered the rear, but I have had slightly-sagged springs. Only once have I ever been on the bump-stops, I was hitched to a too-heavy trailer. And that was just a few miles, from the RV store to a nearby house. If you raise the spring seats in the car, just un-bolt the stock rubber bump-stops, and cut them down to 1/4", then re-install and drive sanely for a while. It'll probably never touch at all. If it is, you're taking curbs at 99 MPH and need a new SVT Raptor
Old May 20, 2012 | 07:13 PM
  #52
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
Originally Posted by BlackenedBird
Not unless you drive stupid. In 2 years of my bumpstops being cut out & running 7"bs 17"x11" rear wheels, I haven't bottomed anything out. Think ahead when driving & all will be just fine.
what setup do you have and any pics?
Old May 20, 2012 | 07:33 PM
  #53
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
17" x 11" ROH Snypers custom widened 2" for 9" wheels, to the inside, on a stock width 9-bolt.
No pics, but I did cut out the bumpstop & part of 1 layer around there pretty much identical to https://www.thirdgen.org/forums/susp...od-17x11s.html ) but I did use Double Adjustable tubular LCAs with the the offset mounts from UMI http://www.umiperformance.com/catalo...roducts_id=107 , plus cutting in the front & rear plus a good deal of BFH work
Put in a 4th gen rear end & then very little sheetmetal work is needed.
Old May 21, 2012 | 06:45 AM
  #54
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
cool thanks!
Old May 21, 2012 | 06:46 AM
  #55
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
so people are saying to trim bumpstops...it may be the first vechicle ive had in awhile where i keep bumpstops at all...haha
Old May 21, 2012 | 02:40 PM
  #56
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Believe me, I know how to drive a slammed car. But in the rear, at 24.5" fender height, you'll only have .5" suspension travel at most before the axle tube will bottom out on the bump stop mount. Even with 200lb rear springs I'll bottom out every now and then. Hence the need to notch the bump stop area.
Of course, this only applies if you're trying to get your car as low as mine or what the OP wants his to be.
Old May 28, 2012 | 02:05 PM
  #57
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
Originally Posted by SCCAjunkie
Issues:
Most lowering springs are NOT MUCH stiffer than stock for F-bodies. This is precisely why I cut my stock springs and sold my Eibach Sportlines. Sportlines will give you the drop and rate you're looking for, and put you on the bump stops just as often. Once you're on the stops, the ride becomes *significantly* stiffer...
Using extended balljoints corrects a problem. The A-arm going up from the inner to outer pivot actually creates handling issues. Granted, with what you're looking for, I doubt you'd be affected by them, so it probably isn't a big deal in your case (or in many others).
One other issue that's often overlooked- many shocks vary in damping rate by position. They "ride nicer" near the center of the stock suspension travel. If you lower the car, you'll probably perceive the ride to be stiffer because of increased damping.
You claim your car already "rides rough". This certainly won't help the situation. Stock spring rate on an 88 TA is supposedly somewhere around 600 lb/in if I recall. Look at what's available from Moog and go softer than that. I'd consider the MOOG-5032 if I were a gambling man...
The point is that no change you make to the suspension will give you a "stock ride" unless you leave it stock. If it were softly sprung at the lower height, you'll be at the lower end of the travel constantly, thus why the factory chose those dimensions and rates.
No one here is going to physically stop you from doing what you propose. If, however, you're looking for us to validate the idea, or moreso to encourage you, I think your time would better be spent on the car.
Also, what are you planning to do with the rear suspension to compensate?
when you say you cut your stock springs.....how much did you cut and how drop did you get? thanks
Old May 29, 2012 | 01:49 PM
  #58
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
I have a full coil off the front, and a half off the rear, I think. Honestly, I have no idea how much drop I have, as the front springs were already cut 1/2 coil (I think) when I got it, and the rears were different, mismatched springs. I'm going for the least-bad suspension angles, not a particular height.
What you can do is measure the distance between coils with the suspension loaded, and use that as a starting point for approximate drop (if there's 2" between coils when loaded, cutting 1 coil will give you *about* 2"). Keep in mind that there is a slight gain in spring rate when cutting due to the change in lever arm length, so you might not get the full drop you calculate. Also, other things can change dynamically, affecting the end ride height.
Remember that if you do make incremental cuts, you should "roll out" the suspension between measurements, so that you don't get a false height due to suspension bind.
Old May 31, 2012 | 08:19 AM
  #59
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
thanks im planning to use all your recommendations! i appreciate your knowledge and willing to help. i'll post before and after pics with measurements when i drop the car in a few weeks...ive got a week planned so i can take my time
morrow
Jan 13, 2024 12:29 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
