Energy Suspension poly motor mounts
Hi,
after drilling out the rivets/welds of my clamshells and installing the new n shinny poly mounts they wouldnt line up with the provided holes in the k-member, after trying back and forth and swapping them around i went back with my old ones, cause i wasnt gonna redrill or slot.
very annoying when aftermarket parts just wont fit as they are supposed to.
anybody out there encountered the same problem?
regards J
regards J
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Energy Suspension poly motor mounts
I had them with no problems. Not sure how the mount will effect wether or not the clamshell part will line up since that part stays the same.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You did something wrong. Simply changing the insert in the mount does not change where the bolt holes are. Sounds like you have 2 different sets of mounts? Are they correct for the car? I'm not sure how this problem could arise?
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Do you have them on the wrong sides? If my memory serves correctly, they only line up perfectly on one side. I could be wrong, but I didn't have any problems installing poly mounts in my car, they lined right up. There are several holes in close proximity. Possible you lined up on the wrong holes?
Car: 1987 Trans Am
Engine: LQ9/L92
ditto, make sure you're using the correct set of holes. our kmembers are drilled for both the v6 and v8 mounts; the v8 setup only uses 3 of the 4 bolt holes in the clamshells
Car: 89 IROC-Z28 Camaro
Engine: 350 TPI IROC
i have an 89 RS with an 89 350 IROC-Z 28 motor. how in the hell do i get to the lower motor mount bolts inside the frame????? do i need to take the motor and suspension off??????
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I used the Energy Suspension Poly mounts and the holes lined up perfectly.I consider myself to be mechanically inclined but removing and installing the motor mounts was one of the hardest things I have done so far .To install them especially the passenger side required a pair of vice gripes on the top so it would not spin while I used a extension with three wobbler's and socket all taped together with electrical tape to keep them from only bending a little instead of wobbling to much. I did this install by myself and the job lasted well into the night. Only fitting because it was a "nightmare".I would never use any thing but poly mounts because of how long they last.I know I'm dreaming but I hope this will be the last time I have to do that.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You need to remove the springs and the lower control arms from the car entirely. Even then the access is hell. And if you're going to the trouble, then just do Moroso solids so you'll never again have any cause to repeat the job.
Engine: TBI,5.0
Just thought Id mention that even though I had intentions on doing the switch myself, I contacted a reputable shop and was quoted $300.00 to do the job.Just one more reason I did it myself.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
It is the same way on S10s. It is a pita but you can do it with all the suspension still mounted.
Whenever I put new bushings in my front arms, Im going to swap the mounts while Im at it.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
84, body, energy, engine, fbody, gen, installing, modify, montecarlo, motor, mount, mounts, polly, poly, suspension, transmission, tras
