Power steering issue
Old Jul 17, 2012 | 12:50 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I got a issue with the power steering with my car. I have a LS swap in my car and went to do the power steering to get the air out of it and it didnt work at all.
I jacked the front end and went lock to lock 30 times and still nothing. drove around the block a few times and still nothing
when I take the cap off you hear a suction sound but im stumped as too what is the issue.
Anyone have a idea what it is? Thanks
Old Jul 18, 2012 | 10:06 PM
6SIX6's Avatar
Car: 89 IROC
Re: Power steering issue
Anyone have a idea what issue I could be having with it. I just don't want to be replacing parts if I don't have to
Old Jul 18, 2012 | 11:56 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
power steering pumps generally should work fine after 10 clock to clock movements. so now just troubleshoot, lines hooked up correct?, leaks?, pump making pressure?, bad steering box? the list goes on u can also disconnect the high pressure line from steering box and start car for like 2 seconds to see if pump is pumping. I honestly cant draw conclusion until you have more info so try some of the troubleshooting
Old Jul 19, 2012 | 12:12 AM
6SIX6's Avatar
Car: 89 IROC
Lines are hooked up correctly as it was the first thing I checked. Havnt seen any leaks at all and its on clean cardboard to see if it is. I will double check it tomorrow. I assume I'm making pressure as when you take the cap of its making a pressure relief sound when you undo it. Steering box was in my last car and it worked fine then with no leaks. I will double check everything in the day tomorrow.
I just want to nake sure the pressure line from the pump to the box goes in the hole closest to the nose of the car and the return is the hole closest to the firewall. Correct? I was told that was the way they go
Old Jul 31, 2012 | 04:37 PM
6SIX6's Avatar
Car: 89 IROC
Ok i swapped the new pump in and the same thing. Swapped the linesand that didnt work. The only thing left is the steering box but Ive never heard of one failing ever. Most people just swap them for the quick ratio IROC ones. I guess I will have to try the box unless someone whos something else to try
Old Aug 1, 2012 | 06:50 AM
ZF6camaroZZ4's Avatar
Car: 86 Z/28 IROC-Z
Axle/Gears: 9 Bolt 3.27
That sounds odd... belt on correct? Like its turn the right direction??
Old Aug 1, 2012 | 08:37 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Are you topping off the power steering pump fluid level after you go clock to clock.
Old Aug 1, 2012 | 12:54 PM
6SIX6's Avatar
Car: 89 IROC
From what I understand I have it the right way unless Im a complete ididot and got it wrong and I sure hope not. Ill have to look up the way the belt goes again to make sure
Its topped off and is at the full mark when I do it
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
