Rack and Pinion Stock K member
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: Rack and Pinion Stock K member
I will take that as a no. Well I will see what I can do.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
It's only been a couple of hours. The real brains here will still be sleeping!
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I welded the mounts on my aftermarket one. I would look to see if you can use one with how forward the front of the k-member is. The aftermarket k-member tube is set back a bit, Get a rack and see if it will work.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I think I will have to notch the k member for the steering shaft but I do not for see any other problems.
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
Nov 16, 2015 01:13 PM
Linson
Aug 21, 2015 02:12 PM
