will these front bump stops work on my car?
Transmission: A4
I need to replace the rubber bump stops on my lower A arms but I am having trouble finding the correct one that fit my application based off of some of these online sites' application info. I did find these .
Question is, will they work on our cars even though the Amazon application chart they dont. They sure look like the ones I removed from my A arms.
Transmission: A4
Re: will these front bump stops work on my car?
Let me add that I will be adding new Koni yellows in a few weeks and I did see the bump stops that Spohn sells that apparently slide over the top of the strut. Do these take the place of the A arm mounted rubber bump stop?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Note the bump stop info in the following link:
https://www.thirdgen.org/forums/susp...s-created.html
JamesC
JamesC
Transmission: A4
Thanks James. From what I can tell now, my car did not have OEM rubber bump stops on the A arms. Someone must have installed some red ones like the ones I posted above. Now, with that being said, can I use the rubber bumper stops that Spohn has that go over the shaft on the struts instead of buying new rubber stock ones? I would post a link but I am on my phone right now
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
