4th gen rear question
Old Sep 1, 2012 | 03:03 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
I just installed a rear diff from a 2000 SS. My question is, why is it sitting 1/2" off, towards the pass. side?
Old Sep 1, 2012 | 04:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 4th gen rear question
probably was before too. Check the condition of the panhard bar.
If its straight and undamaged, you need a adjustable panhard bar to center the axle
Old Sep 1, 2012 | 07:54 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
I have Spohn panhard bar and LCA's that I bought from one of the mods here. It drives perfectly straight and all, but you can tell it is off center and measurements confirm it.
Old Sep 2, 2012 | 06:39 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
My 3rd gen rear was off by 1/2" as well...towards the pass side.
Adj ph-rod (on car) corrected the issue.
Old Sep 2, 2012 | 08:04 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
99% of these cars are like this. You won't really notice it until you put your tires out to the edge of the sheetmetal.
Old Sep 2, 2012 | 09:45 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Not until the tires are closer to the edges of the fenders does it really become noticeable. I was on stock springs, stock wheels with stock sized tires & only 1/2" lower than when it was brand new & mine seemed fine until I put 17"x9" wheels that had a different backspacing (from stock) on them & sat just a bit in from the edge. I got an Adjustable PHB from http://www.umiperformance.com/catalo...fombdeosckah83
Old Sep 2, 2012 | 10:13 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Ok cool, those are the answers I was expecting to hear. Ok, so I won't worry about it for now, and then over winter I'll get an adjustable PHR and take care of it.
Thanks guys.
Old Sep 8, 2012 | 06:54 AM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
My car came with a 4th gen 12bolt rear. A twist on panhard bar centered it perfectly.
Old Sep 11, 2012 | 12:28 PM
BMR Tech's Avatar
Former Sponsor
Not uncommon on the F-body because as the suspension sags or you drop the car, the rearend pushes to the driver's side. As mentioned above, the fix is an adjustable panhard bar.
- Kevin
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
