Steering column swap
Old Nov 5, 2012 | 06:21 PM
btobias86's Avatar
Car: 1991 Camaro RS
Engine: V-8 305
Transmission: Stock
Axle/Gears: Stock
Quick question and thanks in advance for any response.
I needed to replace the steering column in my 91 camaro rs. the only one I was able to find was off of a 92 firebird. everything appears the same from the airbag placement, ignition switch, and how it bolts. I even took measurements as far as lenght and it appeared to be the same. I am trying to figure out if this is suppose to work as a replacement because i am having trouble sliding it into the shaft under the hood.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
