My Front Suspension RestoMod - Opinions?
Car: 1988 Camaro Convertible
Engine: 355
Looking more to see if I missed anything. Ive been up trying to get this part of the build mapped out as more of these parts will need to be purchased ASAP. Also is the pitman arm just a copy of the idler arm so I need to order two?
Tubular K member
Price: $529.95 - Part: KM008 - Manufacturer: BMR
A arms and Coil Over
Price: $939.00- Part: ACP007 - Manufacturer: BMR
Camber/Caster Plates
Price: $169.25 - Part: F-P 124215 - Manufacturer: Founder Performance
Struts
Price: $237.96 - Part: 8741-1030Sport - Manufacturer: Koni
Front Sway Bar
Price: IN HAND ($95.00) - Part: 205270 / 36mm Stock - Manufacturer: Top Down Solutions
Greasable Front Sway Bar Bushing Kit
Price: $42.50 - Part: 200170 - Manufacturer: Top Down Solutions
(2) 1LE End Link Kit
Price: IN HAND ($18.25) Part: 207080 - Manufacturer: Top Down Solutions
(2) Formula 5 Prelube
Price: $3.00 - Part: 200301 - Manufacturer: Top Down Solutions
WonderBar (Steering Brace)
Price: IN HAND $55.00 - Part: 105021 - Manufacturer: Top Down Solutions
(2) Steering Brace "Extra Bolts"
Price: $3.50 - Part: 500250 - Manufacturer: Top Down Solutions
Idler Arm
Price: $40.79 - Part: K6249 - Manufacturer: Moog
Pitman Arm (is it the same part number as the idler???)
(2) Ball Joint
Price: $39.10 - Part: K6145T - Manufacturer: Moog
(1) Center Link
Price: $50.79 - Part: DS1049 - Manufacturer: Moog
(2) Inner Tie Rod Ends
Price: $47.58 - Part: ES2227RL - Manufacturer: Moog
(2) Outer Tire Rod Ends
Price: $28.76 - Part: ES2226RL - Manufacturer: Moog
(2) Tie Rod Sleeves
Price: $15.78 - Part: ES2032S - Manufacturer: Moog
Subframe Connectors
- Alston / TDS
Price: IN HAND $221 - Part: 306020 - Manufacturer: Alston / Top Down Solutions
- UMI Performance Inc
Price: $230 - Part: 2400 - Manufacturer: UMI Performance Inc
Strut Tower Brace
Price: $180.00 - Part: EDE1745226 - Manufacturer: Edelbrock
Everything is getting torn out and replaced with new. Everything that is "upgradeable" I want to upgrade. This is for a convertible. I was going to go with UMI on the k member and all, but I dont want to put the AC compressor up top (which adds another $150 to the cost as well). Anywhere else I can improve? Would like to do it right the first time.
James
Tubular K member
Struts
Front Sway Bar
Idler Arm
(2) Ball Joint
(1) Center Link
(2) Tie Rod Sleeves
Subframe Connectors
- Alston / TDS
Strut Tower Brace
James
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: My Front Suspension RestoMod - Opinions?
Tubular K member
Tubular K member
Transmission: Pro-built 700R4
-Eldon
Engine: 355
That's EXACTLY the kind of suggestions I'm looking for. Thanks for that. Added to my Excel file and will start researching that a bit more.
Here's a link to get you started.
http://www.summitracing.com/parts/ba...w/make/pontiac
Shop around to see if you can find a better deal. Back when I bought mine, Summit didn't even them them yet. IIRC, I got mine from either ThunderRacing or Scoggin-Dickey.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
There is zero mention of upgraded brakes and what wheels and tires you are running...
