upper strut bolt
Old Dec 9, 2012 | 06:02 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
upper strut bolt
I seem to be unable to get the upper strut bolt to break loose. I'm talking about the nut on the very top of the strut in the strut mount. It has the metric allen head in the center and the nut I can't get loose is 3/4"...Is it a reverse thread or something else I'm missing??
Old Dec 9, 2012 | 06:14 PM
Re: upper strut bolt
Put a pipe wrench on the shaft thing of the strut and waylay it with your impact set to "kill".
Old Dec 9, 2012 | 06:28 PM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
lol, yeah I had to take a monkey wrench to mine also...But I got it off.
That bolt is just a beach.
I also sprayed a bunch of pentrant lubricant on mine. WD40 should also help a little.....
GL
Old Dec 9, 2012 | 06:42 PM
Nahhh, just makes the pipe wrench slip.
Old Dec 9, 2012 | 09:01 PM
Car: 89 Formula 350
So are you guys saying to use a pipe wrench on the smooth shaft that sides into the body of the strut? Wouldn't that damage the shaft, also it's covered with a plastic sleeve.
Other question I have is about the spring. Do I need to use the rubber isolator that sits on top of the spring?? I notice they are worn and I have almost a 1/2" difference in ride height between drive and passenger side.
Old Dec 9, 2012 | 09:18 PM
OF COURSE!!! But it's going in the trash ANYWAY, so who cares?
Nothing a coupla quick seconds with a utility knife won't fix.
Old Dec 9, 2012 | 09:30 PM
Car: 89 Formula 350
Struts are not that old so I was planning on using them again. I'm replacing the strut mounts and a arms.
Old Dec 10, 2012 | 12:12 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If you are re-using the struts, penetrating oil and short blasts with a really good impact gun will get the nuts off.
Old Dec 10, 2012 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No, but personally I'd throw them or some new ones back on. I doubt that the 1/2" difference is attributable to the isolators.
JamesC
Old Dec 10, 2012 | 11:26 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Heater Hose Mod and zip ties with a little bearing grease.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
