Installing Rear Lowering Springs..
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Okay so I know this has provably already been answered before but if someone could lead me towards the right thread ide greatly appreciate...but pretty much I already put the eibach sportlines in the front and njow I wanna trow on the rear ones but I cant remember how to do so
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
Re: Installing Rear Lowering Springs..
jack up rear. support frame so rear end hangs free.
unbolt shocks, lower rear end down.
slide out old springs, slide new ones in.
bolt shocks up.
30 min tops
bolt shocks up.
30 min tops
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Be careful not to lower the rear so much that the center brake line ruined.
JamesC
JamesC
Car: 1984 Z28
perfect thanks you guys and they just slide right in?
No...
It's not that hard.
There's not even any "slide" to it. You just kinda set em there in their place, and then have your assistant hold em still so they don't fall out while you jack the rear end back up to the point you can re-attach the shocks.
The springs usually FALL OUT if you take the shocks loose and let the rear hang. FALL. As in, nothing but gravity. Aside from any rusty stuck bolt hassles, probably the easiest thing on the car to change; WAY easier than spark plugs, or even, changing the oil. Takes about twice as long to jack the car up and set it on stands and to take it back off, as it does to change out the springs.
Might as well do the shocks at the same time.
James is right about the brake hose; easiest way around that, is to remove the bolt that holds the little brass block to the rear end housing, that the hose and the lines go into.
It's not that hard.
No need to remove the shocks, if you jack up the rear so the axle hangs free you can with a little force pull the old springs right out and put the new ones in. Takes all of a couple of minutes
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Yeah, its more of a pain in the *** trying to keep the springs in rather than taking them out.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
That is actually a good idea.. When does your car's rear go into a full extention mode though?
That's why I have droop limiters in the rear. The springs sitting loose under full extention is an immediate tech inspection failure here. Some straps...done! Can be bolted to stock arms easily
ignore horrific uglyness LOL
Attachment 253000
Attachment 253000
Doesn't matter if you do hazard style jumps or not, it's a tech failure so it's a problem.
Car: 83Z28 HO
Transmission: G Force 5 speed
Car: 1984 Z28
Engine: LB9, LB9
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sailtexas186548
Aug 26, 2015 03:32 PM
