Want to replace all steering linkages..
Old Feb 28, 2013 | 09:25 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright so I want to replace all the linkages on my steering since everything is stock and who knows how much longer there going to last...but I am not too familiar with what parts I will need......can you guys help me out..?
Also thinking about replacing the strut mounts as well because I also plan on installing a tower brace but my question was what is the big difference between this mount
http://www.summitracing.com/parts/up...t/model/camaro
and this one
http://www.summitracing.com/parts/ky...t/model/camaro
thanks!
Old Feb 28, 2013 | 02:26 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Want to replace all steering linkages..
and this one
thanks!
Picture of front end parts needed.
Attached Thumbnails Want to replace all steering linkages..-spohn-front-end-kit.jpg
Old Feb 28, 2013 | 02:27 PM
DJP87Z28's Avatar
and this one
thanks!
Picture of front end parts needed. Also needed ball joints.
Old Feb 28, 2013 | 02:31 PM
calgutie's Avatar
Car: 1984 Z28
cool thanks I saw thta you got that picture form sphon performance anyway u can post the link...might ust buy everything if the price is good.
Old Feb 28, 2013 | 08:11 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
and this one
thanks!
The aftermarket (UMI) towers are more adjustable. If your vehicle is stock height or within an inch of stock height you would be fine with the regular/stock style strut mounts. If you will or already have the vehicle lowered go with the UMI or Founders or spohn aftermarket mounts. By being a taller mount they allow for more strut travel on lower vehicles. The aftermarket mounts also have more room for adjustment-they are double adjustable. I have heard from many members that our stock strut mounts have as much or more adjustability than aftermarket mustang towers.
Old Feb 28, 2013 | 09:04 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Check with RockAuto on the linkage and ball joints. I replaced mine with Moog parts at a great price.
Old Mar 1, 2013 | 07:17 AM
DJP87Z28's Avatar
One stop shopping for the correct parts. Picture of STB on a TPI (note it dose not use the strut mounts).
Attached Thumbnails Want to replace all steering linkages..-engine-20picture-20front.jpg
Old Mar 1, 2013 | 11:43 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Right on, also the umi are a spherical bearing to decrease or eliminate deflection (more rigid). the kyb are stock replacement and made of rubber. depends on how serious you plan on getting. since I autoX and will be installing weight jacks I plan on getting the UMI ones myself. Founders are cheaper but i like matching parts.
If you answer yes to either of these questions you will benefit from the UMI/founders/whoever strut mounts.
1. is the car lowered?
2. Does the car see track time? AutoX or road race?
Old Mar 1, 2013 | 11:59 PM
calgutie's Avatar
Car: 1984 Z28
pretty much on my car suspesion mods are:
Eibach Sportlines all around
KYB-GR2 all around
36mm fron sway bar
wonder bar
so I think I will be geting the UMI
I also saw that Founder has a descent pair of strut mounts for around $160ish u guys think theres is worth it or should I go with UMI?
Old Mar 2, 2013 | 12:14 AM
Car: 92 Camaro RS
if you go to umi and founders websites they are almost identical in construction so IMHO you might as well save a little coin with the founders. i've seen quite a few people using them in these threads. do a search on the founders caster/camber plates and see what people say about them. I do encourage you to read more than just my input cause i do believe that UMI/founders being raised to help shock travel will be beneficial but i have no idea how it will affect you ride quality as they are also more rigid. so like i said, please read more, search caster/camber plates and see what those that have installed them say about them.
Old Mar 2, 2013 | 12:16 AM
calgutie's Avatar
Car: 1984 Z28
thanks I appreciate your help and yeah ima look more into theres no doubt about that Ima get one of them just not sure yet which one. As for a more rigid ride I dont mind my car already is rought when it comes down to bumpy roads so Im used to ut...as long as it can out corner my friends WRX LOL
Old Mar 2, 2013 | 12:24 AM
Car: 92 Camaro RS
i autoX with some of those, they are quick in every direction.
Old Mar 2, 2013 | 12:32 AM
calgutie's Avatar
Car: 1984 Z28
hell yes they are...there little turbo spool quickly which gives em that edge.
Old Mar 2, 2013 | 09:08 AM
Tibo's Avatar
Car: 1991 Z28 Vert
it is all about the driver. I did Auto cross against a Nissan Sentra SE and he beat everyone but 1 of the Corvette drivers. Most people cannot drive at the full capacity of their vehicle. Myself included.
Old Mar 2, 2013 | 10:49 AM
calgutie's Avatar
Car: 1984 Z28
dang a sentra LOL...well yeah you do have a point..even me I dont go to the fullest.
Old Mar 2, 2013 | 01:32 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
+1
For this kind of stuff you can save a small fortune at rock auto. Quality parts without "Race car" powder coating on them... You can get cheap garbage from rockauto too if you're in a bind, but I dont recommend it.
I got an LS1 brake swap done with a lot of parts from rock auto and was shocked at how cheap some of it was. Longer wheel studs, brake pads, and rotors all for less than $100 if I remember right. For maintenance parts you just cant beat them.
Also, you can go under the car and try to move the steering linkage parts around, or put the car on ramps and watch as someone turns the wheel, and you will see where all the flex is, which will give you an idea of the condition. Fresh parts will have very little flex, they will just move the next part in the chain.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
