Worst Case Scenario With Bad Strut Mounts
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Quick question here guys.
Since we installed a Tokico lowering kit with new struts on my car the old worn strut mounts that are the factory 180k originals for all that I know are really on their way out.
The rubber bushing is completely split about halfway around on each mount.
Now, while I do plan to replace these in the very near future for obvious mechanical, safety and performance reasons with a set of founders or like mounts, I am in a very tight spot money wise ATM and need to ride them out as long as possible.
I was wondering what is the worst case scenario if the rubber surround completely let's go. I am primarily concerned about the strut rod shooting up from the mounting plate and damaging my fiberglass hood. Can this happen?
Car: check
Engine: check
Transmission: check
Re: Worst Case Scenario With Bad Strut Mounts
RBob.
Car: 1985 Z28
as soon as I find myself in the position to spend the money I'm getting the founders mounts. Until then I'll keep a close eye on my failing stockies. Thanks RBob.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I have, in that past, snagged a strut mount or two from the JY for some temporary relief (Nephew's car, Nephew had no money and I'd already put too much of mine into his ride). I really wouldn't go very far with them torn.
Car: 1988 GTA
rockauto has mounts for like $50 a pair or something, I'm having them installed tomorrow. $50 has to be better than my 170k stock mounts.
$29.09 wholesale closeout on TRW strut mounts, with like $9 shipping. With the 5% off that would be near $65 to the door. Gotta love RA.
Car: 1987 Z28
Car: 1987 Z28
Anyone have experience with the TRW or the Mevotech strut mounts listed on rockauto.com? How do they compare to KYB or Moog strut mounts?
Never seen the KYBs, but Moog and TRW are both made by Federal Mogul. I've used Mevotech and Monroe and could tell no difference one from the other.
Car: 1985 Z28
I'm pretty much set on getting the founders mounts. I have put alot of money into the suspension on this car so I think another set of stock style rubber mounts would be a slap in the face to my wonderbar and STB.
I'm just holding on another month or two max before I buy them. I honestly think the rubber mounts were split before I just never noticed it.
Aside from the new engine being built, the only things left on the list for this car slated for 2013 are founders mounts, front end rebuild, power steering rebuild and restore the A/C.
Power steering I have everything except an aluminum pulley and A/C I have everything except a new condensor. Gonna be another fun year once I get back in the wrenching mood from my winter vacation.
Car: 1987 Z28
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I've heard the mevotech is like the economy brand of steering parts. Moog is the best for our cars.
You'll be perfectly fine with Mevotech. I'm a hair picky on ball joints (MOOG) but the rest of it will provide dependable service as long as it's lubed regularly.
When replacing everything, disconnect the old tie rods from the spindles and the center link from the pitman arm and idler arm. Pull it out as a unit and assemble the new stuff to the same length. This should get it close enough for the ride to the alignment place.
A new idler arm should be installed to the same height, relative to the chassis, as the pitman arm. If you do the ball joints, freeze them overnight and use a little oil on install.
All of the tools can be 'rented' at one of the chain stores.
Car: 1985 Z28
The balljoints we just put in last september are already making noise and need to be replaced. They were the POS driveworks off the shelf ones from advance auto (Hey they free so I thought I'd try it!).
I just ordered the replacements from summit and read good things about proforged parts so I gave those a try. Haven't put them on the car yet.
Car: 1987 Z28
I agree with your take on ball joints, I had a pair of Moog's pressed in by a local machine for relatively cheap.
That sounds like great advice for the linkage as I want to make sure everything goes in correctly.
Car: 1987 Z28
Have you heard anything about proforged balljoints?
Car: 1985 Z28
Nice car in sig BTW. I thought me and ronusmc were the only two members here who had the AR-23 wheel.
Car: 1985 Z28
They're my favorite wheel on a thirdgen. I added some black lugnuts and a little wheelpaint to the triangles on mine.
https://www.thirdgen.org/forums/atta...215_101426.jpg
https://www.thirdgen.org/forums/atta...215_161544.jpg
As soon as it stops snowing (Yes I am on the east coast and it is SNOWING in march
), I'm going out to put in the black centercaps.
Are yours 15x8 or 15x10? The fronts almost look deeper than mine but can't really tell.
), I'm going out to put in the black centercaps.Are yours 15x8 or 15x10? The fronts almost look deeper than mine but can't really tell.
Car: 1987 Z28
Car: 1985 Z28
http://toyotires.com/tire/pattern/pr...petition-tires
I wanted the 16" AR-23 but 16" has a very poor tire selection especially for drag radials.
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
