wheel spin
Old Mar 28, 2013 | 08:44 PM
maxjett's Avatar
wheel spin
I have a 90 Camaro have umi adjustable torque arm and panhard bars comp engineering rear shocks set at 30/70. The car just smokes the tires off is there any adjustment I can do with the umi setup to help
Old Mar 28, 2013 | 09:57 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: wheel spin
Yes you can adjust the pinion angle.
What is your current pinion angle?
Old Mar 28, 2013 | 10:00 PM
maxjett's Avatar
Re: wheel spin
to be honest I have no idea what the angle is right now
Old Mar 28, 2013 | 10:02 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: wheel spin
Get a pinion angle finder, get underneath the car and find out.
Then search to see what pinion angle you need for your hp level and driving needs
Old Mar 28, 2013 | 10:05 PM
maxjett's Avatar
Re: wheel spin
ok will do it is going to be a drag car. think I will get the LCAR brackets also see if that helps any
Old Mar 29, 2013 | 03:35 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: wheel spin
What rear tires at what pressure? The relocation brackets should help if you have good control arms.
Old Mar 29, 2013 | 03:39 AM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: wheel spin
What kind of tires?
What kind of engine and what mods are done to it?
Is it spinning on the street or on a well prepped track?
Old Mar 29, 2013 | 03:50 AM
Re: wheel spin
oops!
Old Mar 29, 2013 | 11:23 AM
maxjett's Avatar
Re: wheel spin
it is spinning on the street had cooper cobras on it now have 28x10 slicks. It has umi adjustable control arms on it. Engine is a 350cid dart pro one alum heads light weight crank and pistons 520 lift cam and 175 shot of nitrous. 3500 stall converter
Old Mar 30, 2013 | 12:20 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: wheel spin
It says smokes the tires off,I'm taking it that's both tires with a posi/locker of some sort.
As far as the Cooper Cobras are concerned there made out of a hard compound rated at 50,000 mile tread life and are going to spin especially with that converter/etc. With that engine and a shot of nitrous with that stall your only going to be able to hook at a well prepared track even with your suspension mods. and slicks.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
