How to put a camaro on a tow truck
Old Apr 26, 2013 | 08:42 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Transmission: TH700R4
Hi,
After searching for hours, I haven't found the answer of my problem.
I moved to a new town in December, but my 92 RS is still in my previous home.
Now it's time to bring back my car to the new home.
But the engine doesn't start, so I need to rent tow truck.
My question is how to put the car on the truck?
I don't find a hook under the front of the car.
Where can I hang the hook of the rope to load the car on the truck without destroying the front bumper fascia, especially the front ground effect?
When your car fail, how does the repairman load your car on his truck?
From the front or from the rear of the camaro?
Old Apr 26, 2013 | 08:58 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: How to put a camaro on a tow truck
You really need a roll back. Or they have trucks that pick the car by the front wheels iirc. There is no hook in the front of the car you can tow with.
Old Apr 26, 2013 | 09:01 AM
Joe Tag's Avatar
Originally Posted by wahoo
Hi,
Flatbed it with the car facing the rear. A flatbed should be able to extend far enough out to keep any gfx from scraping during loading. If not,some blocking and ramps under the front wheels should get the nose away from the ground enough.
Old Apr 27, 2013 | 11:09 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Use a flat bed and the tow company should have a strap deal that goes over the tires and straps to the bed. You should always haul a vehicle forward on a flatbed. They can pull it on the bed with the winch and large j-hooks through the a-arms. I used to do towing.
Old Apr 28, 2013 | 08:27 AM
Joe Tag's Avatar
My line of thinking for facing the rear is the cable for the winch has much more clearance to the GFX if you hook up to the rear end. I can see it doing some damage to the chin spoiler while loading and unloading if you pull it on forward facing.
I guess if it comes down to it, you can pull the chin spoiler. But depending on the condition of the bolts and captive nuts, it may be difficult.
The truck that lifts the car by the tires may be ok, but then you have to worry about every bump going down the road, versus just when you are loading and unloading. Which is done at a controlled pace.
Old Apr 28, 2013 | 10:41 AM
Car: 92 Camaro RS
Your not wrong in any way. I said "you should" tow a vehicle forward. Only reason being wind resistance. Best example is if you tow a minivan backwards you will most likely have the rear side windows pop open and break off. It really depends how far your going and what the speeds are between A and B.
Old Apr 28, 2013 | 11:28 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Why not try a car hauler trailer with a come along or a portable winch. You can rent a really nice trailer from U-haul one way.
Old Apr 28, 2013 | 11:36 AM
NotsosleepyZ's Avatar
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
thats how mine is coming home from missouri on the 20 of may, its like 267 dollars but im also towing it 500 plus miles, and you can get insurance fro the trailer incase something happens
Old Apr 28, 2013 | 09:10 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
By chance are you coming up I55 in IL or are you going up farther west??
Old Apr 29, 2013 | 10:25 AM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
i take 72 through missouri to I-35 up through iowa and MN
Old Apr 29, 2013 | 02:14 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Is there any truth about towing with the rear wheels on the ground will damage a 700r4 trans. ?
Old Apr 29, 2013 | 03:10 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I had an alternator/battery die about 30 miles from home at night. The roll-back flatbed tow truck winched it up on the bed from the front and used straps around the a-arms and rear axle to hold it down.. The was no damage to the front spoiler or to any other part of the car. That said, my car isn't lowered and the operator was especially careful putting it on and taking it off. I can't say what would happen with a lowered car and a sloppy operator.
Old Apr 29, 2013 | 03:32 PM
mwarner44's Avatar
This happened to one of my hood louvers. They loaded it backwards and I guess the wind caught it ripped it in half. A couple studs were broken so that gave it just enough leverage to break.
Old Apr 29, 2013 | 07:17 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Use a roll-back truck and load it facing forward. Hook the winch cable to the factory tow points with the small t-hooks. The tow brackets are the metal tabs hanging off of the front subframes with the oval holes. This method will put a little upward pressure on the front facia but that is what the factory intended. Secure the rear with the same kind of t-hooks in the rear frame rails. Use the oval holes that have the doubling plate on the bottom of the rails. That's what they are for. The large j-hooks over the axle is the wrong way and can easily damage brake lines, sway bars, etc. Every car on the road has provisions for towing it from the factory.
Old Apr 30, 2013 | 12:59 AM
TFS355S10's Avatar
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
Yes. Unless you pull the drive shaft it will destroy the transmission. There's no way for the trans to lubricate itself, when the motor isn't running to drive the pump.
Old Apr 30, 2013 | 08:02 PM
Engine: TBI,5.0
Thanks,I would say that is a important thing to know !!!
jhawkeye
May 25, 2022 06:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
squiggy2
Aug 9, 2015 09:30 PM
anesthes
Aug 8, 2015 09:37 PM
