I need a set of stock front hubs
Old May 20, 2013 | 05:06 PM
hotrodf1's Avatar
Car: 91 Z28
Engine: 350ci "fastburn 385"
Transmission: T56 / Quartermaster clutch
Axle/Gears: 9", 4.11, Auburn Posi
Sorry to post this question out here, but I"m in need of a set of stock front hubs.
Seems like the guys parting cars out need to have the hubs on there so the junkyard will take the leftover shell.
Is there another alternative out there that will swap in place (same part from another vehicle perhaps).
In my area, the 3rd gens are pretty much gone from the yards. I haven't seen one in quite a while.
If anyone has a set they can let go, PM me the price PLEASE!
Old May 20, 2013 | 05:09 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: I need a set of stock front hubs
Not sure if I understand but thirdgens use inner and outer bearings packed inside the front brake rotor which is mounted on the spindle using a washer and nut. Each time you put on front rotors you're basically putting new hubs on.
You also probably want this in the Parts Wanted board.
Old May 20, 2013 | 05:51 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
are you talking about spindles? Like this.....
Old May 20, 2013 | 05:53 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Just about every discount parts store has them. They are pretty cheap and the fact that they are also your break rotors I would just change the rotors.
I just checked. Rockauto.com has them starting at $11.68 for economy brand.
Old May 20, 2013 | 05:55 PM
rawley2's Avatar
Attachment 259333
That has to be it.
Old May 20, 2013 | 09:14 PM
hotrodf1's Avatar
Car: 91 Z28
Guys,
My sincere apologies. I haven't ever had the stock setup. And I'm not talking about spindles either.
I have a '91 racecar that has long ago been converted to custom aluminum hubs and 14" disc brakes for racing (not by me).
I thought the "stock" setup would have been iron hubs with rotors that slide over the studs before you put the wheel on. My bad.
Sorry for the confusion, thanks for the info.
So the next question then would be - how are guys making the transition over to 5th gen. big brake rotors? My understanding was that the hole in the middle of the rotor had to be enlarged, but otherwise they fit onto the car - which I assumed meant it did have separate hubs.
Sounds like I need to do some more research.
Reason for all this: the aluminum hubs are giving me fits. Road course racing is of course extremely hard on brakes. The high temps are I believe causing the hubs to expand so much that the press fit to the bearing races goes away, and the race begins to spin in the hub. Doesn't take long until the bearing race "machines" away at the hub and the bearing adjustment setting becomes way too loose.
So I was trying to get back to iron hubs (roughly same material as a steel bearing race, which would have same coefficient of expansion).
Old May 20, 2013 | 09:19 PM
hotrodf1's Avatar
Car: 91 Z28
I guess it looks like this then.
Old May 20, 2013 | 09:36 PM
rawley2's Avatar
Some are turning down the rotor and turning it into a hub.
Others are buying hubs and spindles from places like bigbreakupgrade.com
Check the break board right under this one on the main page.
Old May 20, 2013 | 09:37 PM
rawley2's Avatar
Yes our stock breaks look like that.
Old May 20, 2013 | 09:43 PM
hotrodf1's Avatar
Car: 91 Z28
Is there such a thing as 1LE hubs (that are separate from the rotors)? THought I read something about that.
Old May 20, 2013 | 09:45 PM
Car: 92 Camaro RS
Pictures?
Old May 20, 2013 | 09:48 PM
rawley2's Avatar
http://www.flynbye.com/catalog/c1_p1.html
Take a look there and see if anything is like yours.
I don't recommend buying anything from that asshat but if gives you an idea whats out there.
Old May 21, 2013 | 12:59 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
here is a thread i started a few months ago documenting what i had to do to put '98-'02 Camaro brakes on my car. doing any other brake setup that uses a slip on rotor- C4/C5/C6 Vette, etc.- is similar...
i don't have them on the car yet, but i have all the parts and just need time and ambition to git r dun...
https://www.thirdgen.org/forums/brak...ap-bought.html
Old May 21, 2013 | 06:00 AM
Engine: 383 SBC
Yep. Normal process when people started doing that was to chain drill a rotor on a drill press or by hand, then chisel it till it fell off, and finally use a lathe to turn the rotor down making it smooth and balanced again. Then you have a set of hubs made from a brake rotor.
Old May 21, 2013 | 08:01 AM
hotrodf1's Avatar
Car: 91 Z28
Ok. Sounds like I need a set of rotors to turn into hubs. Thanks for the info guys.
Old May 21, 2013 | 08:07 PM
hotrodf1's Avatar
Car: 91 Z28
Pictures?
Not sure if you mean of the car or brakes . . .
Attached Thumbnails I need a set of stock front hubs-photo-5.jpg   I need a set of stock front hubs-dsc02793-.jpg
Old May 22, 2013 | 04:40 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I've got a new/never used with Timken bearings. Make me a reasonable offer.
Brian
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
