You ever feel like a basketball
Old Jun 6, 2013 | 12:25 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
With a slew of new parts and all the slop gone, I kinda feel like a basketball at times.
more so on the eway when I hit those pressure ridges made by ice freeze that go side to side across the lanes.
a few I know so well, I have to hug the cement wall to my left, as when I hit them at 70 the whole car jumps up and moves over 8-10 inches [the right/semi lane in the area is 3ft deep pot hole city]
feels like im boncing into the next lane at times...........
Guess its a side effect of a good handling, a squishy caddy ride it will never be just real evident as I notice things more.......
Old Jun 6, 2013 | 02:32 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: You ever feel like a basketball
just a sign you need to drive faster In all seriousness, my car always feels better the faster MPH I'm going. Going slow = feels every damn thing on the road imaginable.
Old Jun 19, 2013 | 03:54 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ya know its like riding a 4 wheeler across a corn field at times, you got the whell point where you want to go, but under you the thing is jumping n skipin around on the bumps.
cept I can get up on my toes on the pegs and leg my legs absorb it.
Old Jun 19, 2013 | 09:22 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
ever driven on Montreal roads? Engineers come here to learn how to NOT build the roads like ours lol. Yes, there is nothing we can do about it. Solid rear axle, stiff as hell springs. We are doomed to feel every pothole in existence.
Old Jun 19, 2013 | 04:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
On the street use,
a V6 rear swaybar, rubber end links and a rubber bushings in the control arms/panhard bar (I use rodended stuff, it doesn't bind but its noisy) with good shocks.
It will help stop the hop!
Old Jun 29, 2013 | 12:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ive found that 3/4 of a tank of gas will make it plant its self as part of the road, but you can really feel the extra weight.
Car feels twice as heavy.
I normaly only run half a tank max
Old Jun 29, 2013 | 02:01 PM
Alice89's Avatar
Just out of curiosity, how is your suspension? What kind of shocks/struts do you run? I used to live in new york and had similar roads like what your describing, but my car never skipped over the bumps at all, it just stayed planted. I never felt like I was going to fly into the next lane, what your describing just sounds scary man!
Old Jun 29, 2013 | 02:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
stock spec struts n shocks, nothing real fancy on those yet.
id say it has to be mostly the new frontend parts, all the slop is gone, so slop isn't absorbing part of it, like before.
230K car
Old Jul 14, 2013 | 07:41 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
more info to the riddle, I didn't think about my tool box I carry in whatever car im driving, that 75-100lbs of tool in the very back must be putting the springs in just the right zone to bounce. [more weight with gas takes it out] I changed cars do to the torque arm mount bolt coming out and I had moved it to the back seat as I didn't want to open the back. And the rear end was not jumping anymore.
Old Jul 15, 2013 | 02:39 AM
Alice89's Avatar
75-100lbs of tool box weight in the back probably would ad to the bounce of your car, but the reality is your culprit is more then likely your rear shocks. They are probably totally toast and are practically allowing your car to just ride on it's rear springs. Hence your bounce...
Old Jul 15, 2013 | 08:56 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
I'm with ALLGO. Try some rear shocks. I just changed my rear shocks (from good to better). It helped the situation a lot. Mine was never jumping around, but it did not make you smile- quite the opposite.. Much better, now.... but still, occasionally, lets you know it is a live rear axle.
Old Jul 18, 2013 | 02:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ill check and see if they are still under warranty, rear shocks are only about 10 years old. free is always better
Old Jul 18, 2013 | 02:42 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Would a nice cushion help?
Old Jul 23, 2013 | 09:59 AM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
10 years is a long time lol
Old Jul 28, 2013 | 08:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Is 10 years old for shocks? Maybe im just to use to struts that last nearly forever.
did do the bounce test, old trick, use full weight on a corner and if it bounce 3 times or more, bad shocks.
front don't even bounce one, rear about 5-7 times after full body weight jump.
[Doing rest of front end and torque arm this week, shocks will be next.]
Old Jul 28, 2013 | 11:29 PM
Alice89's Avatar
Damn! 5-7 times lol? Yea that's probably a huge portion of your problem right there..
Also the bounce test has never really worked that well for struts. What I mean is the front of my car didn't bounce at all, yet it had 80,000+ mile original struts that were near dangerous to drive on in my opinion. (Lack of control)
After replacing them it made a massive difference, in a very good way.
Old Jul 29, 2013 | 08:17 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its coming up on the list but gotta do things in stages or sets.
can't just do struts with out, springs n strut tower bearing tops. Gonna hafta group all that into one project for later.
Old Jul 29, 2013 | 02:49 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
huh, standard style suspensions are able to handle well without beating you like tht. harder does not = better.
Old Jul 29, 2013 | 06:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just ordered new shock n sway bar end links from rockauto, got it all for the price of one shock else where.
Though I did drive out of my way to day to goto advance auto for the front sway bar end links as they have the blue ones
Old Jul 31, 2013 | 10:55 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
shocks will arrive today, so I got the rear up in the air while waiting. very obvious now. drivers side lower shock bolt, rust as F as expected, pass side is shiny slick in shock oil.
Old Jul 31, 2013 | 03:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
note when a nut or bolt that your just gonna replace gives you trouble, the drill is the best best lest you have a oxy cuttin torch.
air chisel, hand chisel, trying to break the nut n save the bolt for what? 30min one side, 5min other.
Old Jul 31, 2013 | 07:31 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
This is EXACTLY what shocks are for. They dampen spring oscillations so your car doesn't bounce.
Get good shocks. If you hae cut springs then it will bounce even worse and you will need better shocks and struts to control the higher spring rates. Get good shocks and struts. Even new ones will be crap unless you spend on some good ones.
Old Aug 1, 2013 | 01:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Rears are on and what a difference, now just the front still hop's, so I ordered new struts from Rockauto, same deal, got them and ball joints shipped for same as one strut local.
im using MONROE Sensa-Trac all around.
never been let down with MONROE shocks ride quality.
Old Aug 6, 2013 | 12:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Started the struts with the left side, Seafoam Deep Creep WORKS, had those nasty crusty things come lose like they were new. Plus I worked smarter not harder, used a 4ft bar and just sat on it, just used body weight to get it moving. Nothing esier then sitting come on fedex, im ready.........
Old Aug 6, 2013 | 07:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well that went well, top nut for strut was easiest to just slice down the middle with angle grinder then split it off.
Old Aug 7, 2013 | 12:06 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Total spent at RockAuto $216.46
2 RAYBESTOS innrer tie rods
2 RAYBESTOS outer tie rods
2 RAYBESTOS adjuster sleves
1 RAYBESTOS center link
1 RAYBESTOS idler arm
2 MONROE Sensa-Trac rear shocks
2 MONROE Sensa-Trac front struts
2 rear sway bar links
2 lower ball joints
about $40 of that was shipping as I made 4 orders over a few months, doing parts in stages.
Old Aug 7, 2013 | 12:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hmmm what to do, notice today the left rear is an in lower then the rest, I can fit 4 fingers between top of tire and fender lip, on left rear no go 3- 3 1/2 fingers. [like your gonna shake hands, stick hand into space]
once all apart the right rear shock was leaking but it still kinda worked, left shock was 100% gone, did nothing.
Old Aug 7, 2013 | 11:58 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I measured and left rear is 3/4 of an inch lower then the rest of the car, and man is it buggin me, though not easily seen by eye.
Old Aug 8, 2013 | 01:03 AM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
But your tool box in the right rear of your car.
Sounds like you need new springs now
Old Aug 8, 2013 | 01:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The little misses has done poo pooed the the paper work for funds on new springs for something only I can notice.
I did some searching and allot of people use those rubber or metal spring boosters to level a ride when its just a in or so change. Only down side I could find is some say the metal ones can break a spring but that was a truck board.
Old Aug 9, 2013 | 09:11 PM
Car: 1987 Trans Am
Engine: 355 tpi
You could also cut a half a coil off the spring that is to tall.
Old Aug 13, 2013 | 02:22 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
funny you mention that, while doing things, I notice the right front spring is broken on the bottom, very bottom coil about 6in from end. That side was also missing a bump stop. [ I replaced]
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
