WS6 Sway Bar Swap
Old Jun 11, 2013 | 08:09 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
WS6 Sway Bar Swap
Anyone swap sway bars in from a WS6 car? Any noticable improvements?
Old Jun 12, 2013 | 11:59 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: WS6 Sway Bar Swap
Swapped WS6 bars (36/24) from my stock (30/18) on my '91 Firebird. This was in addition to a Spohn wonderbar and Founders panhardbar. I noticed a more stable, firmer ride. Stays planted in the curves, goes over speed bumps more evenly, doesn't squat on takeoffs, doesn't feel as loose in general. Also swapped from a stock steel to an LS1 aluminum driveshaft. Have a 2 TLTL steering box that I haven't put in yet.
Old Jun 13, 2013 | 06:56 AM
insomniac's Avatar
Engine: 5.7 L98
whats advantages did you get out of the aluminum drive shaft?
Old Jun 13, 2013 | 11:17 AM
antares57's Avatar
In my opinion, compared to previous ride, ...less vibrations, improved gas mileage, less rpms at cruising speed, quicker acceleration. It accelerates to cruising speed much quicker, at cruising don't have to shout to talk to each other or raise the radio volume much. RPMs are 300-500 less per tach than previously at cruising. Gas mileage improved 2-3 mpg in the city and up to 5 mpg on the highway. Sometimes my lead foot doesn't notice when I go from 80 mph to 90 mph.
Old Jun 13, 2013 | 11:38 AM
insomniac's Avatar
Engine: 5.7 L98
from sway bars? how do they effect rpm?
Old Jun 13, 2013 | 01:52 PM
antares57's Avatar
You asked about the driveshaft.
Old Jun 13, 2013 | 02:01 PM
insomniac's Avatar
Engine: 5.7 L98
oh yeah. brain fart
but how does an aluminum drive shaft effect rpm. isnt it still spun the same?
Old Jun 13, 2013 | 02:35 PM
antares57's Avatar
oh yeah. brain fart
I won't even begin to tell you I understand it. It's just what I've observed. Good info link below.
https://www.thirdgen.org/forums/tran...riveshaft.html
Old Jun 13, 2013 | 03:19 PM
insomniac's Avatar
Engine: 5.7 L98
im sold, just ordered a aluminum from a 95. Now i got to play the u joint game to see how to mount it to my 9 bolt rear
update: **** shows up at the shop its steel f'n idiot parts guy on the phone said "yeah its aluminum".. sent that guy away
Old Jun 14, 2013 | 03:10 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I bought a new inland empire 3" aluminum driveshaft. Very good quality and reduces vibrations alot.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
