ES tq arm mount install help
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Re: ES tq arm mount install help
You can try what I did with my UMI torque arm, but you aren`t going to like it...
I basically forced the clamshell as far as it could go, and then wedged a piece of wood between the clamshell and tunnel....
Gathered more strength, forced it a little more closed and shimmed the wood until I could get the bolt close enough to start threading.
It sure was a pain in the butt, and somewhat ghetto, but it worked.
I hope someone has a better solution for you...
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Did u grind the rivets out of the old rubber torque arm bushing if u didnt the mount will not fit no matter what u try
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Find or go to hardware store for slightly longer bolt - grade doesn't matter. Use that to torque down the first time (use washers if needed), then remove and use original bolt.
A c clamp wont fit in the tunnel
Use you WILL instead of relying on your CAN'T.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Just making sure, but you do have the right one right? They make 2 different mounts depending on the torque arm you have. If you have the wrong one, it will drive you crazy. I know.
Terrell351
Jun 13, 2021 01:13 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LT1Formula
Nov 16, 2015 01:13 PM
