Tack weld LCA bushing to stock LCA ?
Old Aug 18, 2013 | 12:21 PM
whatdayasay's Avatar
Should new pressed in LCA bushings be tacked welded to the stock LCA?
If so, can that tack welding be done after the LCA is installed?
Old Aug 18, 2013 | 12:50 PM
Re: Tack weld LCA bushing to stock LCA ?
No.
See answer #1.
Old Aug 20, 2013 | 12:30 PM
83 Crossfire TA's Avatar
after a couple of bushing swaps the holes can get a little loose, if they do tacking them in makes sure they don't move. I don't see why you couldn't do it with the LCA installed, but if they were loose you would have noticed before you put them in, I hope...
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
NBrehm
Aug 5, 2015 07:57 PM
