Cutting Moog Springs- Info inside
Old Aug 20, 2013 | 06:12 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I will be cutting my Front Moog 5662 springs tomorrow. I want about a 1-2" drop. As of now I am just going to cut half a coil, then reinstall over and over untill I get my desired ride height.
EDIT: I cut the springs with an angle grinder and cut off disc. I cut .75 of a coil and resulted in about a 1.5" drop. I would recommend not to cut more than .75 of a coil off at a time as you might cut too much. Also remember to get an alignment after the drop.
I noticed a small improvement in handling. Nothing major. My ride quality wasn't effected at all.
Before, 28" Fender Height
After, 26 5/8" (photo is flipped to show same orientation as above photo.)
I know I looked for a while and couldn't find much info on the topic. So now this thread will be pulled up in searches.
Any one else who have cut their moog springs with results, feel free to post.
Old Aug 21, 2013 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Cutting Moog 5662, how much drop?
Interestingly enough, the 5662's dropped my IROC a bit without cutting. Might be wise to throw them in first and see what you think.
JamesC
Old Aug 21, 2013 | 09:11 PM
Axle/Gears: 4.10
JamesC I have been running the springs for a couple of months at stock height. When I originally installed the springs it lowered my car about a 1/4" as well.
I went ahead and cut .75 of a coil and got about a 1.75" drop. The front looks great now. Next is the rear.
Old Aug 24, 2013 | 09:07 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Cutting Moog Springs- Info inside
Did you changed your bumpstops?
I cut a half coil off mine and it put the bumpstop very close, I got some trim to fit traction bar snubbers to replace the stockers.
Old Aug 24, 2013 | 01:24 PM
JamesC's Avatar
The bump stops on 16" wheels are taller than those for 15" inches.
JamesC
Old Aug 24, 2013 | 01:47 PM
Car: 1971 Camaro
Engine: 427
JamesC
So are you suggesting people swtich to the bumpstops for 15" wheels?
Are they reproduced?
Old Aug 24, 2013 | 06:03 PM
JamesC's Avatar
I did.
Yes. More info in the following link:
https://www.thirdgen.org/forums/susp...s-created.html
JamesC
Old Aug 25, 2013 | 08:20 PM
Axle/Gears: 4.10
The bump stops were not an issue for me. I just drove the car on about a 150 mile round trip on the interstate, and it drove great. It didn't bottom out once, even over bridges and dips
Old Aug 25, 2013 | 09:27 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I wouldnt suggest cutting more than a HALF coil TOTAL off EVER on these springs. The spring rates cannot be balanced front to rear when you cut that much off the front springs. The spring rates become insanely high putting a much higher load on your struts and shocks. Hope you have some Koni's.
If you need more than a 1 inch drop, you get drop springs or weight jacks. In my opinion, it's not safe to ride around with unbalanced front-rear spring rates. It will cause oversteer and the rears will hit their grip limit in cornering long before the fronts, assuming the sway bars are set up for a factory-balanced setup.
Old Aug 26, 2013 | 12:11 PM
Axle/Gears: 4.10
I see what you mean. I'm not too worried though, as I have read some others cut .5-1 coil off moog springs with good long term results. Plus I am not going to run my car hard for a while. I had plans to get weight jacks next year at the start of autoX season.
I don't think the spring rate is nearly high enough to cause unsafe street scenarios. I can't really tell much of a difference in spring rate since I have cut them. The car rides very smooth. I did "test" the handling by taking some nice corners at different rates of speed, the rear end seems pretty planted. Actually it seemed a little more planted with the lower CG.
Old Aug 26, 2013 | 01:05 PM
Car: 1992 Camaro RS
I cut 1/3 of a coil off my front IROC springs and I could tell a huge difference in spring rate. The rears are progressive rate so their rate increases MUCH faster than the fronts. You can probably counteract this by going to a smaller rear sway bar, or removing it. Most of the autocross and road race guys go for the smallest rear sway bars they can, and many dont run a rear sway bar at all.
Your "tests" amount to "It feels better therefore it is better." Until you find the grip limit you dont know how it's going to act when you get there. That's always the concern. "feeling planted" and having predictable, managable handling behavior at and beyond the limit of grip are completely different things.
Old Aug 26, 2013 | 05:02 PM
Axle/Gears: 4.10
Good info there.
That's why I put test as "test". I know it did not give me real accurate results. But I am fine with that, as my car never sees beyond the grip limit. Especialy since it is a 305/A4. I can only see me loosing traction that leads to oversteer in emergency street situations.
Now next year, when I get my GC Jacks along with Konis or KYB AGX struts/shocks I will then dial in suspension to the ride height, ride quality, and performance I desire. Untill then it's easy driving from point A to B.
Old Aug 26, 2013 | 10:29 PM
Car: 1992 Camaro RS
Good info there.
It's not like it will be any worse than the guys who run fatties and skinnies with bias ply tires. Imbalances arent the worst thing in the world. Best thing to do is save for some weight jacks, I think. In the mean time it will look pretty cool, and since the spring rates on these cars vary depending on a lot of factors, it may not even be that far from "correct".
Old Feb 17, 2019 | 09:47 AM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Gonna bump-the-bump-stops-to-the-trump era:
James I think I get the benefit of 2” bump stops on 16” wheels vs the 2.25” (with stock springs) but wouldn’t the car be more “joincy” with the extra space?
Old Feb 17, 2019 | 11:08 AM
JamesC's Avatar
Bump stop height for 16" wheels is 2 1/4". Factory design.
"Jouncy"? Try poly. Ask me how I know, lol.
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Aug 15, 2021 10:16 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
