Those with caster/camber plates
Old Sep 9, 2013 | 09:27 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I'm looking for advice on the best/easiest way to adjust my camber when i go to the track. I started with a compromising -1.5* camber but it's not enough for the track so i want to start adjusting between a track and street setting.
Old Sep 12, 2013 | 08:42 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Those with caster/camber plates
I'm not sure what your'e asking but if you want to switch between two settings you will need to take the car to an alignment shop and have them put the car at one setting, then outline the plate and mount by etching the paint and then setting it to the other. Just eyeballing it is not a good idea.
Old Sep 12, 2013 | 09:22 PM
Car: 92 Camaro RS
Thanks for responding. I have done all that. I'm looking for tips and techniques on adjusting the camber when I get to the track. Do I have to lift/jack up the front or can I adjust them on the ground?
When I installed everything this spring I had it aligned and set the camber at -1.5º but through the summer I decided its not enough for the track so I went back to the shop (tuesday), had it realigned a lil more street friendly and had them mark the front edge of the plate to keep track of caster, and mark 0 to -3º camber. Right now the camber is at -1º for street but I plan to try -3º next time I go to the track. What's the easiest/best way to adjust the CC plates at the track? I have everything set up to do it I'm just looking for some voices of experience from fellow autoXers who have done camber adjustments at the track.
Old Sep 12, 2013 | 09:44 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Just loosen the 3 nuts, push the plate towards the engine, and tighten the bolts. You might need a friend to help. It's very easy to "eyeball" a camber adjustment.
Old Sep 12, 2013 | 10:41 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Unless you have an exact spot marked so you can easily return it to the prior setting, eyeballing it is not a good idea. Unless you have known settings marked, Alignment is a either done with time and patience at home with a few measuring tools or by an expensive machine. Eyeballing without measuring it or using known settings is only OK when it's just to get you through the drive to the suspension shop after a disassembly.
Old Sep 13, 2013 | 06:56 AM
Car: 92 Camaro RS
So, basically I can easily adjust them with the car on the ground, at the track, with only a wrench and there won't be any issues? (As long as I have everything marked, which I do)
Old Sep 13, 2013 | 10:28 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
hmm won't they just fly up because of the pressure from the struts if he doesn't jack up the car?
Old Sep 13, 2013 | 05:43 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
You don't remove the nuts, just loosen them. You'll have to push it really hard. It's easier when you can move it and hold it in place while a friend tightens the nuts.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
