replace strut mount when replacing struts?
Old Sep 20, 2013 | 04:04 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
From what I can see, my front strut mounts are fine.
Now, they may end up less than fine when I start wrenching on them.
After all, the look like they've been right where they are for a quarter-century.
Other than the possibility that I will wreck the mounts in the process of removing the old struts, is there any reason to replace the mounts as a matter of routine when replacing the struts?
Old Sep 20, 2013 | 08:54 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: replace strut mount when replacing struts?
Yes!
Factory mounts use rubber bushings = sloppy
Use the search function and research. I have and recommend the Spohn units.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
Leggman1
Aug 6, 2015 04:15 AM
