Options to cushion a rough ride
Old Nov 22, 2013 | 11:11 AM
motley1987's Avatar
Since I bought my 84 Trans Am I replaced the wheels with the OEM 205's which are not low profile in any way and double checked to make sure the air pressure was right. The problem is when I drive it, it still rides pretty firm to where I feel every little bump in the road, almost like the tire pressure is too high. I pushed down on all four ends and the shocks seemed pretty firm and when I had it in for the tires the guy said the shocks seemed like they were in good shape. I'm not sure if they're OEM shocks or a more firm performance shock, but I'd like to do something to make the ride a little softer and not so harsh. I'm not looking for a ride like a cadillac but I'd like to not get jostled around so much. Is there something in the suspension I should look for that could be worn and causing such a stiff ride? I can't imagine the ride was this rough when it was new. I had a 69 Cougar that had a much softer ride so I figure there has to be something I can do to help the ride. Any help, tips or suggestions would be great. Thanks!
Ben
Old Nov 22, 2013 | 11:34 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Options to cushion a rough ride
What size wheels and tires?
How long have you had the car?
How many miles?
New struts and shocks would be where I would start in terns of ride quality.
Good bushings, and rear control arms can also make quite a difference.
Old Nov 22, 2013 | 11:35 AM
Car: 1971 Camaro
Engine: 427
Being a trans am, it would have stiff springs.
You could replace them with lower rate base model springs.
Old Nov 22, 2013 | 11:44 AM
Car: 1971 Camaro
Engine: 427
And how much pressure are you running?
Old Nov 22, 2013 | 11:54 AM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Stop complaining about your trans am riding rough and buy a BMW. I'm amazed at the amount of people on here complaining about ride quality....
Old Nov 22, 2013 | 12:17 PM
Car: 1971 Camaro
Engine: 427
Old Nov 22, 2013 | 12:19 PM
motley1987's Avatar
It has just over 95,000 miles and I've had it about a month. The wheels are 14 inch wheels and I'm running 205-70 14's with 28 psi. Since I'm planning on driving this almost everyday as a daily driver and cruising and not looking to either race it or take exit ramps at 70mph, I don't need a stiff performance type ride. If anyone has a suggestion for replacement springs or struts I'd appreciate it. Thanks for the info!
Old Nov 22, 2013 | 12:26 PM
Car: 1971 Camaro
Engine: 427
Buy the best struts and shocks you can afford.
Cheapest to consider would be KYB GR-2 fronts and gas adjust rears, or KYB AGX, Tokicos, Bilsteins or Konis.
Just go to the parts store and get new Moog springs for a V6 model.
Replace all suspension bushings with new, after all they are 30 years old now.
Old Nov 22, 2013 | 12:29 PM
motley1987's Avatar
That's a good start. Thanks for the help. Like I said, I don't need it to ride like it's floating, but there has to be a happy medium. Thanks again.
Old Nov 22, 2013 | 12:31 PM
Car: 1971 Camaro
Engine: 427
Just remember it is a 30 years old sports car.
Old Nov 22, 2013 | 12:37 PM
motley1987's Avatar
Yeah, I'm not expecting a complete 180, I just want to make it as good as it can be.
seiplentz
Aug 19, 2019 06:02 PM
Linson
Sep 21, 2015 01:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
Ranbo108
Sep 9, 2015 12:20 PM
