Camber/Caster plate recommendation
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
Car- 88 trans am gta, all the front suspension stuff is getting replaced. I am using koni yellows with either the pro kit or sportlines. It looks like getting a part store replacement, w/lifetime warranty, isn't much cheaper than getting the founders plates. Car is going to be a daily driver. One thing I am concerned with when it comes to the founders is harshness and tons of road noise. With stock replacements I am worried about alignment problems. Some post say stock has enough adjustment some say no. What is the right part or part recommendation?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Camber/Caster plate recommendation
You wont see much road noise with the founders pieces or anyother of the available plates.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I'm pretty sure OE has enough adjustment but lowered vehicles do benefit from the raised strut mounts of founders, j&m products, UMI. They say it helps keep the struts from bottoming out from being lowered.I bought J&M products which i now know were identical to founders. Founders has improved their product since then, so to me the choice is a no brainer.
https://www.thirdgen.org/forums/susp...-improved.html
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
monte87cortez
Sep 26, 2015 08:10 PM
