Quick steering box adjustment question
Car: 1991 RS
Engine: L69?
Can this be done on the ground or do I absolutely have to get the front end up? My jack just crapped out on me and I really want to try and get rid of some of my slop while the weather is still warm.
Car: 1991 RS
Engine: L69?
Re: Quick steering box adjustment question
I keep getting conflicting info on this.. Some say it's ok as long as you back the adjustment plug out more than 90* and test drive to check for binding, and some say it'll wreck the box... I'll take you word for it, nobody on this site has ever steered me wrong.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The over center adjustment will not take slop out of the box. Not really sure where the idea came from that it will. It will adjust how much the steering returns to center and overall "stiffness" of the steering, but it WONT do anything about the slop in your wheel. That has to be adjusted by resetting the input shaft preload, which is next to impossible to do on the car and requires a good torque wrench and a special tool to hold the plug.
Drive it as is until you have a chance to rebuild the box.
Car: 1991 RS
Engine: L69?
Ouch... Was hoping to avoid that. I guess when everyone says it reduces slop it's more of a placebo effect of the tighter wheel then?
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Car: 1991 RS
Engine: L69?
the adjustment I was originally inquiring about, according to his post, is what will do that. I did it earlier, I swear I feel slightly less off center play, and it's definitely tighter to turn and respond
Engine: L98 494hp
Where is the adjustment on the box? which way do you turn it to increase the stiffness?
Car: 1991 RS
Engine: L69?
It's directly on top, there is a lock nut with an adjustment plug in the middle. Hold the allen wrench on the plug to keep it there, loosen the lock nut a few turns, then tighten the adjustment plug until snug, and then back it out about a quarter to half turn and hold it while you tighten up the lock. Check for binding lock to lock and adjust again if necessary.
Engine: L98 494hp
Cool, that's an easy adjustment...I've been needing to stiffen it up ever since I replaced the gearbox. Thanks, I'll try it out
backtothe80s
Sep 5, 2015 12:39 AM
