steering box bolt size??
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I need to purchase some bolts for steering box can't find mine.
Want to go into home depot and walk out ready to go!
Don't wanna pull those damn things from the junkyard.
Re: steering box bolt size??
If memory serves they are 12mm, "std" thread for that size. (not sure but I think it's 1.5mm) Something around 120mm long, maybe a bit more. Doesn't matter if they're a little too long.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Special type of bolts. Junkyard pull or dealer only.
They're probably metric but should also be a flanged head, tapered starting thread etc.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
LOL hybrid cars! Probably metric threads with standard head size! Silly GM in the 80's!
Car: `86 SS / `87 SS
Metric bolts started around 1979 for the steering gear.
Home Depot doesn't do metric bolts to suit car applications like that.
GM shows disco. on the bolts. Call a salvage yard. Or hit the classifieds on here.
Car: 1988 Camaro
$10 + shipping for the 3 gearbox to frame mounting bolts.
Car: 1984 Trans Am
A place like Fastenal might carry them. Not sure if you have one near you.
What are these bolts called? I'm trying to search for them but can't figure out a name for them
Car: 1988 Camaro
I do not know the correct term for them. I have alway just called them the steering gear box mounting bolts
Car: 1988 Camaro
For bolts like that unless you want to try to make hardware store bolts work (which you can find at home depot, lowes, ace, tractor supply, etc), as far as I know the only source is used from a car. Junk yard, or used parts dealer. Hawks, third gen ranch, camaro heaven, etc would have them.
I have them. $10 + shipping for the 3 gearbox to frame bolts.
Car: 1988 Camaro
Do you have paypal? If so then just give me your zip code so I can get you a shipping quote, then just send the money through paypal and your name/shipping address and I will mail/ship them right out to you.
I do my very best to do next day after payment shipping and most times depending on location you will get item 2 to 4 days after I ship it out.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
