support belt rear axle
Old Mar 8, 2014 | 09:46 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi!
Dont now what its called but i wounder what that support belt that connects the axle whit the chassi so it want fall down is called.
Looking for a new one,hope you understand what I mean.
Old Mar 8, 2014 | 10:19 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: support belt rear axle
panrod location bar =upper one
panrod bar = lower one
Old Mar 8, 2014 | 12:01 PM
gt4373's Avatar
Transmission: 5-Speed Manual
If Your Referring to Part # 4,GM Calls That A Rear Axle Tie Rod Brace. It Still May Be Available From Your GM Dealer.
Just Curious Who/When Coined The Name Panrod For This Part.
Old Mar 9, 2014 | 10:30 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
No its not,its a textile peace thats connected to the axle,on my 92.
Old Mar 9, 2014 | 11:17 AM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
You're not talking about the rubber brake hose are you, the one that goes to right over the center of the axle?
Old Mar 9, 2014 | 10:34 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Sounds like a limiting strap.
This?
Old Mar 10, 2014 | 08:48 AM
gt4373's Avatar
midnightfirews6 What Years/Models Had That,I've Never Seen That Before.
Old Mar 10, 2014 | 09:04 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
There you have it,have it on my 92 but not on my 89 ?
Old Mar 10, 2014 | 09:46 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
That's not a factory part. You can see where someone hacked up the control arm.
It's called a limiter strap. On jeeps we use them to keep the axle from dropping too far when off-roading because the spring will fall out.
On our firebirds, the rear springs will fall out if you drop the axle far enough, but I don't know how that would be possible with the car on the ground.
Old Mar 10, 2014 | 10:04 AM
gt4373's Avatar
I Knew That Couldn't Have Been A Factory Part.
Old Mar 12, 2014 | 07:11 AM
Twin_Turbo's Avatar
How is that control arm hacked up? All it takes is drilling a hole......
Old Mar 12, 2014 | 11:15 AM
stealtht/a's Avatar
first of all, i apologize to the OP , I didn't realize that wasn't a pic of his car.
we still aren't sure which part you mean.
twinturbo- poor choice of words on my part. just meant you could see the hole was not factory (it is a little rough)
Old Mar 12, 2014 | 01:54 PM
Nexed you'll have guys wanting the same thing on there car..
and no my 92 Z28. Did not come with anything like that...lol
Old Apr 19, 2017 | 04:49 AM
Twin_Turbo's Avatar
Actually it IS a factory hole, the early 82 83 cars (some) have a stiffener bolted into the LCAs from the factory that uses those 2 holes (actually 4, since 2 each side) It's not hacked up in any way. The only drilled hole is in the inner fender support structure
The diagram GT4373 posted shows this as parts 21 and 22
Old Apr 19, 2017 | 07:28 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
To answer the earlier question, it's called a Panhard bar after Rene' Panhard, whose French automobile company Panhard invented the suspension system using the bar early in the 20th century.
Old Apr 19, 2017 | 09:33 AM
Drew's Avatar
Originally Posted by Twin_Turbo
Actually it IS a factory hole, the early 82 83 cars (some) have a stiffener bolted into the LCAs from the factory that uses those 2 holes (actually 4, since 2 each side) It's not hacked up in any way. The only drilled hole is in the inner fender support structure.
I'll see your brace, and raise you...
Actually, the control arms are a shared part with other GM's. One such application uses those holes to anchor the rear sway bar. Some engineer probably figured without they sway bar they needed the stiffener... Either way the holes are always there, with or without spacers or sway bars.
Old Apr 19, 2017 | 10:00 AM
Twin_Turbo's Avatar
I know, my 86 monte carlo ss has that. I figured Id keep it f body to demonstrate they are factory holes
Old Apr 19, 2017 | 06:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That does not answer the question. And the question was already answered 3 years ago.
Old Apr 20, 2017 | 09:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Im more curious why twin turbo waited 3 yrs to reply!
Old Apr 20, 2017 | 11:18 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
My bet is he was cleaning out old bookmarks.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
E Rod
Aug 28, 2015 05:17 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
