endlink frrustration
Old Mar 8, 2014 | 01:38 PM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
I must be the craziest guy for thinking that things should go back together as easy as it came apart. As simple as sway bar endlinks are they are whoopin my butt. I replaced them with autozone endlinks and can't get them to fit at all like the bar is crooked I know the bar had tension on it that it doesn't hqve now but that can't be the whole problem. Home mechanic with no lift or special tools. Help!!! Any tips. Its like the bar became an in shorter and the end link is too short I'll post pics
Old Mar 8, 2014 | 02:32 PM
Car: 91RS
Re: endlink frrustration
Bolt is 7in
Attached Thumbnails endlink frrustration-img-20140308-00505.jpg   endlink frrustration-img-20140308-00506.jpg
Old Mar 8, 2014 | 04:09 PM
gt4373's Avatar
Transmission: 5-Speed Manual
I See Your Wheel Is Off And Your Suspension Is Just Hanging,Did You Try Jacking The Lower Control Arm Up Towards The Sway Bar.
Old Mar 8, 2014 | 06:28 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Aren't they supposed to be installed and tightened with the suspension NOT in full droop?
Old Mar 8, 2014 | 07:15 PM
Really doesn't matter to their function, where the suspension is when they're tightened; unlike a very few certain other parts, notably, control arm bushings.
In the case of sway bar parts, the whole bar and end links and all that, is in its "neutral" position with the car at normal ride height. The bar is only under tension when the 2 sides of the front suspension are at different heights.
For no other reason than to avoid this particular problem, it's ALOT eeeeeeeezier to install these things on ramps, with the wheels on, than to jack the car up and take the wheels off.
OP: put your wheels back on, drive the car up onto your ramps, and make it eeeeeeezy on yourself.
Old Mar 8, 2014 | 10:35 PM
Car: 91RS
Will try tomorrow thx erryboy
Old Mar 9, 2014 | 01:38 PM
Car: 91RS
I might have to wait till motor is bak in I have to change the oil pan gasket again eventually I'll git it so it won't leak
Old Mar 9, 2014 | 10:01 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
i installed my end links, sway bar and wander bar with the car on the ground. My shop has a 4" lip that i can pull the car up near the edge on 2"x6" boards and i can work on some things (like the aforementioned). Much easier than ramps sometimes.
Old Mar 10, 2014 | 09:01 AM
Car: 91RS
ok i'll wait till I hve the motor back in that might make a world of difference b/c right now it looks like the bolt is about 3/4in too short but its the one that autozone recommends or do I have the wrong ones http://www.autozone.com/autozone/acc...mString=search like I said the ones I have have a bolt that is roughly 7in long then all the bushings and the washers take up almost all the length. I wonder if a grade 8 (8in) bolt would do the trick and then let me torque it to specs. or maybe does someone have any part#'s see the diff. in the length? http://www.hawksthirdgenparts.com/pr...uspension.html
91Firecrow305TBI
Dec 5, 2001 06:05 AM
JamesC
Feb 25, 2001 02:22 PM
ONEFINE8T9
Jan 14, 2001 11:27 PM
Zepher
Dec 18, 2000 01:29 PM
JDMZ28
Sep 18, 2000 02:55 PM
