TRACTION! I Have None
Old Apr 1, 2014 | 08:20 PM
kzmiaz's Avatar
Looking for help getting my car to hook.
What we are dealing with is an 87 GTA with a superramed 383. She pulled close to 400 HP at the wheels and over 450 ft-lbs in a nice linear fashion.
Out back I have installed a Strange S60 diff with 373 gears, in between you will find a TKO600.
BMR Tubular control arms and a Sphon torque arm (connects to cross member not tranny) work with a stock panhard bar hold everything in place.
The Strange rear end has integrated LCR brackets and I have them installed on the bottom hole.
QA1 Double adjustable shocks are also installed on the rear end. Front end is stock with the exception of poly bushings all the way around.
Traction is seriously elusive. I plan on adding some MT ET Street Radials this spring but would appreciate any suggestions you guys have in getting this thing planted. I don't know where to start or what to adjust next, nothing I try seams to help.
Any and all suggestions are appreciated!
Old Apr 1, 2014 | 08:39 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: TRACTION! I Have None
Start with the subframe connectors, tires, shocks, control arms, panhard bar and maybe some relocation brackets for the rear control arms to put them 2degs down in the rear..
remove the front swaybar for track action.
Old Apr 1, 2014 | 08:40 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I’m not trying to even suggest I’m able to roll with the big dogs here but my little 5.0 with Eaton posi and 3.42 ratio would also spin from a stop if I punched it until it hooked but I put my tools back in the rear compartment (100 lbs est.) and it actually cut the spin time in half.
Also it’s the tires that will make the most difference. Mine are the hard as rock "dreaded" Cooper Cobras. I’m sure changing them to a street/drag tire and keeping the extra weight in the rear would do it. That would also test out my little built 10 bolt.
Most of the time I just ease into it with a power break until I get a slight roll then let off the break and that cuts down spin for me.
Old Apr 1, 2014 | 08:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
40lb bags of cement in the rear...
you can go faster, heavier, if it helps you hook better......
Old Apr 1, 2014 | 09:10 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
tires, and move the battery to the back.
Old Apr 2, 2014 | 07:03 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Looking at the parts you have already listed, do the tires. They are key. Then adjust the shocks and suspension to dial it in.
Old Apr 2, 2014 | 07:24 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Definitely tires, and relocate some weight to the back. These cars are really light in the back.
Also, I didn't see anything about subframe connectors so if you don't have those you wanna get them before you get that thing to hook up and twist the car like a pretzel.
Old Apr 2, 2014 | 09:06 AM
kzmiaz's Avatar
Thanks guys. Good tires are definitely on the list for this spring. Anyone have any experience with the Mickey Thompson ET Street Radials? Its not a daily driver but it is a street car and I would like it to hook on the street.....open to suggestions.
Also is anyone else running the QA1's and if so can anyone provide a starting point for adjusting them?
Thanks again for all your input, help and suggestions!
And ya subframe connectors are on the list too.
Old Apr 2, 2014 | 09:41 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
BEST drag radials seem to be Hoosiers...... BUT the ET DR's will be good(especially the Pro Version.)
Also, check your pinion angle on the torque arm. That will make a big difference. Info on setting that up should be on here as well.
Air pressure. Drag Radials at 20 psi will do good on the street and be OK to drive on as well. If you won't be hitting it from a stop too much, then 32 psi will be better for the longevity of the tires.
Old Apr 2, 2014 | 10:07 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Ambient temperature, come on down! Your cold mountain temps aren't going to help. Parts are good --> Tires!
Old Apr 2, 2014 | 07:43 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i'm running the et street drag radials on the street and they seem to help traction a lot, especially with low pressures as suggested. currently i'm running the 255/50/16.
http://www.summitracing.com/parts/mtt-3793r/overview/
next set i'm gonna try a little bigger tire. it should fit. gonna try the 295/50/16.
http://www.summitracing.com/parts/mtt-3794r/overview/
even though i'll effectively loose a lil gear ratio with them being a taller tire, i think it will help with traction. kinda wish i would have ordered them the first time.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
