1991 Z28 Front Sway Bar Bushing Size...
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
OK..So I've searched, and read the limited number of front sway bar bushing sizes threads, and still have questions after researching as much as possible..Now I'm wondering..What size do I have?..I took an open end wrench to my front bar,but only had up to 1 1/2",and it still didnt go around it....but it was only like an 1/8th away..So Heres my dilemma...do I have 37mm bushings...1 7/16" bushings...or 38mm bushings..or 1 5/16 bushings...too close to call.....not sure what else to do, but definitely dont wanna remove old ones,til I have new ones ready to go....thanks for reading!...
Re: 1991 Z28 Front Sway Bar Bushing Size...
Well there's no 37 or 38mm sway bars that came on ANY of these cars, so that settles that.
It came w either 34mm solid or 36mm hollow. Hollow ones have drain holes, solid don't. Not hard to figure out which one it is, from there.
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Easiest way will be just to check with a pair of calipers. You said 1 1/2" wrench wouldn't go over the bar, so...not sure as that would make it larger than anything I have seen on them.
Car: 91 Z28
Thats an answer i can live with..thanks for the help...ill move forward with that....ron
Car: 91 Z28
So..I did move forward..I ordered the Spohn 36mm bracket and greasable bushings....p/n..poly-36-8292f.....Installed and ready to go...easy install..my only concern is that the spohns brackets dont have a "tail" that locks into place on the frame like stock do....time will tell if i did the right thing with the spohn.....
1992rs/ss
Jan 31, 2025 05:10 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
