Who makes knuckles/spindles for our cars?
I need a new passenger side knuckle/spindle as I suspect mine is bent. I simply don't trust a used one from just anywhere because they bend so easily just hitting curbs and stuff that even on a car being parted out that shows no damage, this could still be bent.
Does anyone know where I can get a replacement that's new? I've had an ad in the wanted for awhile and no luck so I just want to buy new.
My local O'Reilly's had no idea where to start...
Thanks!
Alex
Thanks!
Alex
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Who makes knuckles/spindles for our cars?
Classic industries had them in their catalog a few years are, haven't looked recently. They were brutally expensive though.
I might a couple good ones in the garage from old projects, the later style casting too. Ill check tonight
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
You could try a dozen junkyard ones for the price of a classic industries spindle. I'd find a used one.
I worked in a junkyard/salvage yard. cars in junkyards aren't always junk. Most of the time ONE single problem sends them there like an engine, trans, or brakes because the owner can't fix it themselves and can't afford the cost to pay a shop. Don't be so nervous about a junkyard car. If its wrecked, then maybe the spindle could be messed up but if the car is straight then it's probably as good as any.
1 Post
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I doubt its bent unless you hot a curb at 60 mph or something. Bending a spindle really is not that easy to do.
Car: 91 Z28 Coupe
I had to buy a drive side spindle last winter when anothe driver used me to stop her car. Well, HawksThirdGen has used spindles for (IIRC) about $60. Yes it was used, but for the price of a new OEM one ($300+), if you can find one, it is well worth it.
These spindles are cast arent they? They're not really going to be very flexible... they'll just break I think.
I would go for a factory spindle over anything newly manufactured or fabricated. The factory spindles are designed so that GM doesnt get sued for parts failures killing their customers.
Engine: 4++,350 & 305 CIs
They actually do bend fairly easy.
Linson
08-21-2015 02:12 PM
db057
08-11-2015 10:11 PM
mustangman65_79
08-11-2015 03:17 PM
