Steering Column Question
Old Apr 10, 2015 | 01:51 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Hey guys,
Looking into replacing my factory steering column with a simple fabricated shaft. My turn signals, wipers, washers, flashers, and ignition have been relocated off the column already. My question is how does the end of the steering column in the engine bay connect (or mate) with the steering shaft that goes to the sheering box?
Simple question, any input appreciated.
Bill
Old Apr 10, 2015 | 03:18 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: Steering Column Question
You can buy a steering u joint with a 3/4 round on one side and a double d on the other side from Borgeson.
http://borgeson.com/xcart/catalog/Co...-p-1-c-24.html
Old Apr 10, 2015 | 04:43 PM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
I may have worded my question wrong. I know I can use a u joint to hook a round shaft for my column to a dd shaft. But im looking to figure out how the stock steering column goes into the stock steering shaft? Is it just a spline fitting?
Old Apr 24, 2015 | 09:07 AM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
Can anyone provide any guidance?
Old Apr 25, 2015 | 11:50 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
pull it apart and look at it... that would be quicker than sitting around waiting for someone else to pull theirs apart and look at it..
Old Apr 25, 2015 | 12:35 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
A stock column bolts to the shaft. I do have a stripped down standard tilt column here if you're interested. It has no upper shroud, stalk, or ignition but should bolt right up.
Unless you're trying to save weight and not have tilt, a Berlinetta column would fit those requirements almost perfectly. About the only thing on it are the ignition and tilt.
Since you're at it, you might also want to look into replacing the rag joint portion with an Astro Van or Jeep steering shaft.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
