UMI rear arm relocation brackets
Old Jun 13, 2015 | 11:03 AM
crzycamaro86's Avatar
Is anyone running these and if so do you like them and what location are you running with stock springs in the rear??????
Old Jun 13, 2015 | 04:28 PM
powder white's Avatar
Car: 82 Z28
Engine: 350 LT1
Re: UMI rear arm relocation brackets
i have them welded in i have 1'' lowering springs and kyb shocks addjustable panard bar
also up graded the sway bar am running them on last bolt
Old Jun 16, 2015 | 01:37 PM
UMI Performance's Avatar
You can run the lowest hole with stock springs for good forward traction. You can experiment as well. We added a third hole for more rear tuning. For forward traction place the rear control arm with the rear of it slightly lower than the front.
Old Jun 16, 2015 | 01:58 PM
Tnx
Old Jun 16, 2015 | 02:24 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I am running the founders bolt in model 1" drop and love them
Old Jun 16, 2015 | 02:53 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
worth every penny for them IF you are lowered. i have bolt in founders.
they will do nothing for you if you arent lowered as the control arms are already at the optimal angle.
Old Jun 16, 2015 | 02:58 PM
midias's Avatar
http://www.foundersperformance.com/c...tion-Brackets/
These are what I have. They are a super tight fit and every hole will just barely clear the bolts but I like that a lot.
Old Jun 16, 2015 | 06:39 PM
racerkilla's Avatar
Car: 85 iroc with 92 ground effects
Engine: 355 11.1 world product heads
Transmission: t56
Axle/Gears: 3.54 dana 44
I run the umi ones and they fit great. I like how they hooked to the shock mounting bolt. My car is lowered though. They got rid any wheel hop I was having
Old Jun 17, 2015 | 03:45 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
what is the "optimum angle", because mine are pointed down a lot.. chassis mounting point is about 1" lower than the mounting point on the rear axle, as measured from the level concrete floor of my garage. my car sits quite high, since it's a pretty stripped down car with brand new IROC replacement Moog springs in it.. if i lower the rear, it will just point them down farther in the front.
Old Jun 26, 2015 | 10:23 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
GM didn't have the finished product of these cars as engineered as well as you might think, easily evidenced with the additional "braces" you see all over the front half of the car. There are long and plentiful discussions about the GM engineers on these boards. But all that aside you do not need not to have a lowered car to need the relocation brackets. These cars have defective geometry that was designed in and gets worse as the springs sag. At one point I had new Moog stock springs and joints and the body mount side of the LCA was lower than the differential side by 3*. There are also many good discussions about the optimum angle but just ensuring that the body mount is higher than the differential mount will get you in the ball park.
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
