wheelie?
Old Oct 11, 2015 | 05:59 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
wheelie?
made some record passes this weekend at the track. best was an 11.508@117. cam close to pulling the fronts too. any thoughts on how to get them up?
Old Oct 11, 2015 | 07:36 PM
Re: wheelie?
Nitrous
Old Oct 11, 2015 | 07:43 PM
ziggy89's Avatar
Engine: 383
Re: wheelie?
Nitrous
motor isn't even remotely set up for nitrous.
Old Oct 12, 2015 | 12:09 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: wheelie?
What was your 60' times?
I ran a 11.40's @ 118 with a best of 1.61 60' and got the front wheels about 2-3" off the track.
If you are any more than 1.65 60' you need to look at your rear tires and suspension.
Do you still have the front sway bar hooked up or on the car? If so remove it and it might just be enough to get you there.
What is the details of your suspension and chassis, gear and converter?
Get more weight off of the nose. Move more weight to the rear
Old Oct 12, 2015 | 01:48 PM
ziggy89's Avatar
Engine: 383
Re: wheelie?
275/60/15 mickey Thompson et streets with a 4.11 gear. Tubular rear suspension all spohn. Adjustable shocks and struts. Aluminum heads fiberglass hood. It is still a 700r4 car so its foot braked but have a 3600 stall converter. I was sixty footing 1.58-1.60 so she was leaving hard. Sway bar is still hooked up. Thought about that after the fact.
Also thought about moving the batter back.
Old Oct 12, 2015 | 05:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: wheelie?
Weight transfer, lots of traction, lots of torque.
Before our local track shut down, I was able to carry the front wheel to the 60' mark. Changed nothing and went to a track with much better track prep and put the car up onto the back bumper twice.
Old Oct 12, 2015 | 11:16 PM
Car: 1988 Camaro
Re: wheelie?
You are looking pretty good. Only thing I can see would be weight transfer and maybe a little nose heavy.
You are running real close to what my old combo done and the only things right off hand I can see diff is the battery and the sway bar. I left my bar on the car but unbolted the end links. Also my battery is in the rear.
Dumb question but got to ask anyway.. Do you have sub frame connectors? How about a roll bar/cage?
Just thinking out loud... Maybe chassis/uni body is flexing.
I'm running spohn SFC and S&W 10 pt. cage
Old Oct 13, 2015 | 05:23 PM
ziggy89's Avatar
Engine: 383
Re: wheelie?
Got umi weld in square tube sub frames. No bar or cage.
BlownBird
Apr 29, 2005 12:47 AM
Acceld Z
Apr 21, 2003 11:19 PM
Kevin91Z
Nov 15, 2002 10:46 PM
Zirtbow
Aug 6, 2002 07:48 PM
350turbo411
Apr 10, 2002 02:36 PM
