strange clunk
Old Dec 21, 2001 | 10:38 AM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
strange clunk
There's a strange clunk coming from what sounds like the back left area of my trans am. I know that the shocks are shot, do you think getting new ones will stop the clunk? Any other suggestions?
Old Dec 21, 2001 | 10:42 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Replacing the shocks certainly wont hurt. While you are under there, have a look at the control arm bushings, and the bushings on the panhard bar as well. If you have a lot of miles on your car, chances are good that the bushings could stand to be replaced.
Another thing to check would be the sway bar end links. (provided you have one......) They can contribute to noise as well.
have fun.
Old Dec 21, 2001 | 11:06 AM
ploegi's Avatar
Engine: 5.7 TPI
have fun.
Old Dec 21, 2001 | 11:20 AM
ede's Avatar
ede
replace your trans mount it's broke. buy a poly one from ES for the same price as stock and never have to replace one again.
Old Dec 21, 2001 | 05:09 PM
84 t/a 5.0's Avatar
Oh, forgot to say that it doesn't do it too often, only when i turn a corner fast, and sometimes over bumps. Thanks for the help
Old Dec 23, 2001 | 12:54 PM
82zm6's Avatar
check your lower shock mount bolts... mine was doing the samething, and my drivers side mount bolt had come loose. look under the car and get someone to jounce the rear up and down, this should help you locate the noise.
Old Dec 27, 2001 | 01:55 AM
SgtSkip's Avatar
Ede...Whats es?? I need a trans mount too...
Old Dec 29, 2001 | 08:57 PM
SgtSkip's Avatar
ttt
Old Dec 29, 2001 | 11:04 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
ES = Energy Suspension
Old Dec 30, 2001 | 12:49 PM
SgtSkip's Avatar
Good to go. It sounds like something I can find in my Summit catalog...
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
luvofjah
Sep 26, 2015 08:28 PM
BWilcox
Sep 20, 2015 12:19 PM
ynk1121
Sep 12, 2015 12:27 AM
