Founders panhard relocation kit doesn't fit..
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't know if this is a problem with the product, or my car. I'm thinking the mount on the right side is tweeked, probably from a previous owner spinning out and hitting a curb ?
Check out the attached pictures.
-- Joe
-- Joe
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Re: Founders panhard relocation kit doesn't fit..
Have you tried doing the three bolts to the body first. Keep them loose and then try the passenger side?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
If your factory mount was installed and not visibly damaged, than the founders piece is off.
Car: 86 Trans Am
I've had 2 of these parts from UMI on two different cars, one of which had some damage to the driver side rear mount from a curbing incident, and both fit with no problems
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I measured and the bar is the right length. Something is goofy with the car.
I guess we'll fix it with the porta power.
-- Joe
-- Joe
That looks like the brace that goes across the chassis above the panhard bar?
If so, it's essentially the rear "frame", to the limited extent these cars have such a thing.
When you unbolt it, the whole car body sags. Imagine setting a cardboard box on the floor and filling it with sand, with a brace across the top to hold the sides together, then suddenly taking that brace away: that's what happens to the car body. The whole thing slumps without its support. The sides flex in and out as the floor pan sags up and down. SFCs help somewhat but since there's nothing similar bracing it from side to side, they don't cure it.
Looks like in your case, the car bent so much when that support was removed, that you can't put it back without straightening the car back out. Might be as simple as jacking it up from underneath somewhere (inside the trans tunnel would prolly be the best place) with a piece of 2x12 or something to spread out the load, to flex it back where it belongs. As if, that brace is REALLY doing something to hold the car straight, and isn't just useless dead weight.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm considering an adjustable panhard to re-center the rear end if I'm not successful.
-- Joe
Engine: 4++,350 & 305 CIs
Even some hard cornering over and over can move parts on these cars a little bit over time. Pull it back and it'll be good to go. Also a adjustable PHB is pretty much mandatory on these cars.
Abubaca
Dec 28, 2015 09:31 AM
