Can I put 295's on my IROC rims?
Old Dec 31, 2001 | 04:53 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I know they are a little large for 8" rims, but I love the look of wider tires. Will it be safe to do this?
Old Dec 31, 2001 | 05:05 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
It would fit about as well as the Goodyear blimp would fit in a pickle jar.
I'm just curious where you found 295/??/16 tires The only thing I've seen near that size are gumbo mudders.
Old Dec 31, 2001 | 09:53 AM
KS91Z28's Avatar
I have 295s on my IROC rims and they look great. The only problem I have with them is them rubbing on the inner fender well in the back when I take corners fast.
Old Jan 1, 2002 | 12:37 AM
LarsZ28's Avatar
I have 295's on the rear of my 83 Z28, with the 15 x 7 Z28 rims.. Also have a 9" in the rear so the wheels dont rub, because its been modified to fit with these wheels.. I have 265's up front, and they rub a little on full lock.
Old Jan 2, 2002 | 03:05 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks guys. KS91Z28 Did they help with traction at all? I can handle a little rubbing...
Old Jan 2, 2002 | 09:14 AM
KS91Z28's Avatar
They didn't seem to help me. It's one those things were you have the weight dispersed over a greater area, but at the same time you have that much more tread making contact with the pavement.
Old Jan 2, 2002 | 03:37 PM
IROCKZ4me's Avatar
Assuming that you compaire the same model of tires, you will generaly get more traction from a smaller tire on the correct sized wheel than from a larger tire on a wheel that is too small for it. When mounted on a wheel that is too narrow, radial tires sidewalls are overly wedge shaped hurting the tires performance in both straight line traction and turning. The tread surface also bulges in the center (like an over inflated tire) causing less of the tires tread to push firmly onto the road surface, again hurting traction.
You can get away with a slightly under sized wheel with bias ply tires with fewer sidewall plies and nonradial belt design because they have a flatter tread that is not as dependant on sidewall shape.
Usually 295s should be mounted on a 10"-11" wheel.
Old Jan 3, 2002 | 03:01 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Perfect, thank you! Question answered.
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
