front struts
Old Dec 31, 2001 | 03:37 PM
88greyiroc's Avatar
front struts
how hard is it to change the front struts and the strut mounts? it there anything that can really go wrong could someone in detail please tell me everything involved in doin it?
Old Dec 31, 2001 | 05:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A jack and a couple of jack stands are all that's required. Air tools make the job go a lot easier.
Jack up the car and support it by the frame letting the suspension drop. Use the jack to lift up the suspension by the lower a-frame. Unbolt the 2 lower mount bolts and the brake line bracket from the strut. Unbolt the top nut and pull it put.
Old Dec 31, 2001 | 07:41 PM
88greyiroc's Avatar
doesn't the new strut mount have to be set a special way?
Old Dec 31, 2001 | 08:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're not changing the strut mount, only the strut.
Old Dec 31, 2001 | 10:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The strut mount should be simply bolted in. You only need to change it if the bearing is worn out. I think it will only go in one way.
Old Jan 1, 2002 | 09:43 PM
88greyiroc's Avatar
so after i got the car all up do i take the top apart first or the bottom?then when i get to the bottom does the rotor have to come off or can i work around it?cause i don't know how to take the rotor off.please tell me the details in steps what to do i am changing my strut mounts too.
Old Jan 1, 2002 | 10:56 PM
1984Firebird502's Avatar
After you put the struts on you have to have the wheels aligned for our cars.
Old Jan 1, 2002 | 11:10 PM
88greyiroc's Avatar
i know that but i have to get them off first!!!!
Old Jan 2, 2002 | 07:25 AM
Pat Hall's Avatar
Do it just like Stephen said. You don't have to do anything with the rotor, it shouldn't be in the way. Make sure to undo the lower mounting bolts first. When I changed mine, the manual told me to undo the top nuts first, then jack up the car. When you do it this way, the suspension just keeps dropping as you jack up the car, and the wheel never lifts off the ground. It also makes it easier to get the lower mounting bolts undone with the top of the strut still bolted in. If you don't have a really strong impact wrench, you'll probably need a nice long section of pipe and a breaker bar to get the lower bolts loose. Remember, up top, only remove the center nut on the stem of the strut. If you loosen the upper strut mount, you'll knock the car wayyyy out of alignment.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
redmaroz
Apr 25, 2017 07:14 AM
