bump stops for 91 camaro rs?
Car: 91 Chevy Camaro RS
Engine: 350 Crate Motor
Hi, trying to find out which aftermarket bump stops can be used on the 3rd gen camaro? I have a 91 camaro rs and I'm trying to replace the front and rear bumpstops with an energy suspension or poly material replacement. If anyone knows could they include part numbers please. Thanks for the help. Take care.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: bump stops for 91 camaro rs?
Nothing available as a direct replacement, just measure the heights and see what you can find close.
That said, why do you want poly as the bump stop? Poly is rather hard and the stock rubber is better suited for the job
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I swapped in ES poly on the A-arms many months ago, and eventually returned to rubber—the jarring was a bit too much for me. BTW, there are two different OE bump stops. More info below:
https://www.thirdgen.org/forums/susp...s-created.html
JamesC
JamesC
