STRUT BAR
Old Dec 14, 2017 | 02:20 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
STRUT BAR
well long story short Im in the middle of switching from a TPI set up to a HSR an my BMR 3 point bar doesn't fit anymore so
I want to see pic of anyone that has a STB with a carb set up.
trying to figure out if it will work or am I gonna have to make one..
Old Dec 14, 2017 | 02:30 PM
Abubaca's Avatar
Re: STRUT BAR
Not sure you'll find one that'll work. I know edelbrock used to make a carb/TBI brace, but I think even if you go in front the HSR, you're going to run into issues with the intake tubing.
Anything is possible though, so I'll keep and eye out to see what you come up with, or find that works. I know a lot of the HSR guys would be interested.
Old Dec 14, 2017 | 02:33 PM
Abubaca's Avatar
Re: STRUT BAR
google search edelbrock TBI strut tower brace.
TONS of pics! ...looks like it would almost work, but the front bar might hit the underside of the throttle body. Little welding...you might be on to something.
Old Dec 14, 2017 | 02:35 PM
Abubaca's Avatar
Re: STRUT BAR
https://www.thirdgen.org/forums/fabr...rut-tower.html
Old Dec 14, 2017 | 03:44 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Re: STRUT BAR
Thanks for the link..gonna try an do something like that this winter
Old Dec 14, 2017 | 11:08 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: STRUT BAR
If you decide to start with the old Edelbrock design, QA1 bought that from Edelbrock, and still makes them.
https://www.qa1.net/suspension/stree...t-tower-braces
Old Dec 16, 2017 | 04:10 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: STRUT BAR
Does this picture work?
Old Dec 20, 2017 | 03:14 PM
Abubaca's Avatar
Re: STRUT BAR
Tibo, do you have a pic from the side? Do you think it'd clear the throttle body on a TPI or HSR? Some pics of that brace make it look like it's possible, others look nowhere close. In your pic, it looks like it would ever so slightly tuck in right under the cast oval-inlet part of the TB, just in front of the IAC housing. (HSR) ....but again....so hard to really see.
....of course, if it WERE possible, I'm sure Eddy/QA1 would be quick to point that out!
Aaron12873
Convertibles
25
Nov 18, 2024 03:00 PM
Aaron12873
Group Purchases
Aug 3, 2015 08:43 AM
Steven6282
Mar 23, 2012 02:19 AM
mbarland
Mar 28, 2001 05:36 PM
Chris 611
Feb 6, 2001 02:28 PM
