You get what you pay for.
Old Dec 25, 2017 | 10:35 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Well i picked up a zexel rear end off a ls1 for 40 bucks if you saw my other post. Thinking i got a great deal. But as the saying goes you get what you pay for. Finished installing it. Did some some burnouts before i even took it for a test drive. Well the rear passenger tire has a bad whobble. Actually the axle im guessing as i changed the tire to see if it still whobbled and it did. Doesnt make any noises like bearings gone bad just wobbles. Is it the axle? Can i just swap it out ? piece of cake? I was also thinking the axle housing is bent too but probably not. Help a wrencher out.
Old Dec 26, 2017 | 12:02 AM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Re: You get what you pay for.
Bent axle shaft.
Old Dec 30, 2017 | 06:33 AM
KCG's Avatar
KCG
Car: 89 IROC
Did you swap rear brakes or use the LS brakes?
Old Jan 1, 2018 | 08:48 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Bent axle shaft. Very common on 10 bolts with a tire that has any sort of traction. I actually bent an axle shaft in my dana 44. Took me 3 months to realize it. The car had an ever so slight vibration on the highway that I just assumed was the drag radials, and then one day while strapped on the dyno I noticed one rear tire oscillating. Pulled the rear rims off, and started the car with the rear on jackstands. Put it in gear and watched the rear axle flanges and sure enough it had a noticeable bend. Easy enough fix.
Some places can actually mount your bent axle to a machine and grind the hub down smooth again, since they normally bent right at the end there where the wheel mounts. But with a 10 bolt, I'd assume you could pick up another axle shaft real cheap.
Old Jan 8, 2018 | 12:24 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Yeah I used the LS brakes and boy do they stop way better them the drums obviously.
Old Jan 8, 2018 | 12:25 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
So yeah it was a bent axle. Not bad for a 40 dollar zexel. Easy as 1 2 3 to swap out. Thanks bros
insomniac
May 8, 2011 10:22 PM
Calderone
Jan 8, 2007 06:37 PM
Z28 Boy
Dec 3, 2003 06:16 AM
L98IROCZ89
Dec 1, 2002 09:56 PM
junkyarddog
Aug 9, 2001 10:20 AM
