Did I set my pinion angle properly?
Old Jun 13, 2018 | 08:31 PM
BuiltZ28's Avatar
I checked the angle of transmission output and found it to be a +1. I set the pinion angle to a -3 with the thinking you take equal but opposite angles then add 2 additional degrees to the pinion to account for the thrust (raising force) on the pinion when power applied.
All in all I have a +1 on my output and a -3 on the pinion with the suspension loaded.
Also slightly unrelated, what is the effect of raising or lowering the front of the torque arm on my BMR crossmember.
Old Jun 13, 2018 | 09:01 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Did I set my pinion angle properly?
Auto car you want around a -2 or -3 degrees
Old Jun 13, 2018 | 09:04 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Old Jun 13, 2018 | 09:15 PM
BuiltZ28's Avatar
I watched that video earlier I don't really understand it. I have seen a lot of knowledgable people on here saying ignore the driveshaft angle as well.
The car is manual if it matters.
Old Jun 13, 2018 | 09:21 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
You take the numbers from the driveshaft and rearend and adjust the torque arm accordingly to get the numbers you need
Example
Driveshaft +3
Rearend is a -5
That gives you a -2 so you're in the ball park
Old Jun 13, 2018 | 09:23 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Here is the UMI instructions if it helps, says manual should be between 1-3 degrees negative
https://static.summitracing.com/glob...20-%202203.pdf
BuiltZ28's Avatar
Ill check it that way tomorrow see where I'm at.
Old Jun 13, 2018 | 09:34 PM
skinny z's Avatar
No manufacturer can state what the pinion angle should be unless the existing values are supplied. That is to say, you have to know what the angle "down" is of the output shaft/ crankshaft centreline.
There is very little "thrust" in the torque armed 3rd gen. Even less so with poly mounts, etc.
If the crank centreline is down 4 degrees (which is the standard OEM engine angle) then adjust the pinion up 4 degrees. Take 1 degree out (so it's up 3 degrees) if you feel it's necessary.
The real deal here is what the relationship is when you're cruising. There's no upward action on the pinion when at steady state and you want the angles as close as possible for periods where the relationship is extended such as when on the highway.
remltr
Oct 1, 2009 08:11 AM
3ZMan
Nov 13, 2007 11:23 PM
83 Crossfire TA
Jan 16, 2006 10:25 AM
Steves ZZ5
Jan 18, 2001 12:46 PM
