Want to go the air-ride route for my show Z28. Stock K-member is best?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
After a lot of thought I have decided the Z28 build I am doing will move more in the direction of a show car. Air-ride will be a must since I want to lower it a ton for shows, and lift it up to get into my driveway and go over speed pumps, etc.
I sold all of my aftermarket tubular pieces so I am starting from scratch.
I think a stock K-member and A-arms is the way to go. Weld in some gussets, etc. to beef it up if needed.
What is the best way to get a nice stock K-member and A-arms and is this the best route to go for air-ride?
Currently I have the car up on a home made rotisserie getting ready to strip and paint the underside.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Want to go the air-ride route for my show Z28. Stock K-member is best?
The stock parts don't really need and beefing up, they are quite beefy already.
I don't see how aftermarket pieces or stock pieces would be better than the other unless the air ride kit was designed to fit a certain part. Anything can be modified to work.
The stock k and a arms often pop up for sale, usually pretty cheap, or maybe get lucky at as local bone yard.
I offered before I think, but I have a stock k member you can have if you ever make the trip down this way. From a 92, low mile car with nothing wrong with it. I don't have the control arms unfortunatly.
Engine: LS3
Hey 86, yes I think you did offer at some point. I spent some time yesterday looking for that post and couldn't find it.
Where are you located? I don't see why grabbing some A arms off Hawks would be too bad.
Bone yards are tough for parts like this as the work to pull might be prohibitive.
dennisbernal91z
11-07-2017 02:13 PM
Kandied91z
09-20-2008 09:24 AM
brettrocks
Southern California Area
08-31-2004 01:22 PM
