Lower front wheel gap
Old Sep 22, 2018 | 07:33 PM
SBNJ84Z28's Avatar
Car: 84 Camaro Z28
Engine: 305HO
Transmission: 5 Spd
Axle/Gears: 373 Gears
I'm looking to drop the front end of my ride to close some wheel gap. The front shocks springs are original, the rear were changed by the original owner with air shocks. My question is, do I change our the springs just in the front or all the way around? What springs would drop my ride about an inch to 1.5 inches?
Old Sep 24, 2018 | 09:47 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Lower front wheel gap
I would replace the stock ball joints with a pair of extended ball joints. There is a proforged ball joint that provides a 1/2" drop, Howe is 3/4" and Summit brand is 1.0" drop. The extended ball joints would lower the car while not hurting the front roll center. That will let you keep your springs and replace the old front ball joints. You'd want to look into a new set of raised strut mounts to be safe though, that would allow you to keep the same shocks but any air shock should probably be replaced anyway.
bbc632
Aug 24, 2014 09:33 PM
mbolte
Sep 3, 2009 03:00 PM
no_car_yet
Dec 1, 2004 05:26 PM
Sickness91Z28
Nov 12, 2004 08:43 AM
